cold blooded
Old Sep 9, 2004 | 06:21 PM
DiabolicalDave's Avatar
DiabolicalDave
Default cold blooded
I've got a '90 with a 427; speed density. I could go on but I'm looking for more basic problems. It's developed a significant "stumble" when cold. I've gone to a 3-wire O2 (long ago) and checked the fuse and it's not blown. No vacuum leaks. What else? My short list includes looking at the wires to the O2 and even pulling the plug off it and keying the ignition and confirming it's getting power, checking the plugs for fouling, checking for condensation in the vacuum lines to MAP and fuel regulator. Any other ideas?
Old Sep 9, 2004 | 07:49 PM
96GS#007's Avatar
96GS#007
I had a problem with my '90 many years ago. First thing in the morning it had a huge off-idle stumble. Within a minute or two it was fine the rest of the day unless it sat a looooog time. After many dollars spent and countless hours troubleshooting, I found the problem. It was a stretched timing chain. Probably not your problem, but thought I'd throw it out there.
Old Sep 9, 2004 | 10:02 PM
StealDads67's Avatar
StealDads67
Coolant temp sensor possibly.... Hook it up to a scanner and see what its reading
Old Sep 9, 2004 | 10:16 PM
DiabolicalDave
Coolant temp sensor isn't it - I have a scanner and the coolant temp looks right.
Stretched timing chain is highly unlikely - only about 1000 miles on the engine.
What does the IAC do? I'm not real familiar with it's operation. If it was screwed up I guess that could do this but it wouldn't make sense for it to only do it when cold, right?
To cold blooded
