4+3 trans
Old Sep 10, 2004 | 05:30 PM
canon1414's Avatar
canon1414
Default 4+3 trans
i heard that 4+3 transmisions didn't last too long os that true or are they ok
Old Sep 10, 2004 | 05:51 PM
rws.1's Avatar
rws.1
A long time or a lot of miles???
I have not problems with my '88, but its low miles
Old Sep 10, 2004 | 06:05 PM
scorp508's Avatar
scorp508
Depends on the year. My '87 went 166k miles before I snapped 2 or 3 teeth off of the cluster gear from too much abuse.
Old Sep 10, 2004 | 07:35 PM
byte_me's Avatar
byte_me
The earlier years were more problematic...they worked out the bugs as they went on in later installs...my 84 4+3 went out with 47K miles on the clock...could have been lack of driving on the first owners part...but nonetheless- it went (carrier bearing) If you keep the fluid changed with a filter at regular intervals, it should last a good time...as with most mechanical things...proper care usually benefits in the long run!
Cheers!
To 4+3 trans
