anti sieze
Old Sep 10, 2004 | 10:39 PM
tsmsck2's Avatar
tsmsck2
4th Gear
Default anti sieze
are there different types of anti sieze? some only for aluminum?
Old Sep 10, 2004 | 11:51 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I've never seen one specific to aluminum but there might be. I know the regular type works fine for every metal I've ever used it for. When I lived in the rust belt I could put it on exhaust stud nuts, for example, and be able to remove them easily years later. Great stuff, one of my favorite automotive chemicals.
Old Sep 10, 2004 | 11:53 PM
comp's Avatar
comp
Old Sep 11, 2004 | 02:13 AM
tsmsck2's Avatar
tsmsck2
4th Gear
thanks for the info!!
Old Sep 11, 2004 | 08:01 AM
SS409 425HP's Avatar
SS409 425HP
http://www.jetlube.com/NewFiles/aseaz.html
Anti seize compounds are formulated for specific use. Check out this web site for info.
Old Sep 12, 2004 | 01:00 AM
skeet's Avatar
skeet
Anti-seize used on electrical connections (spark plugs) needs to conduct electricity well. No use using the best plugs only to not allow all the current to go through it. That is why I use aircraft anti-seize for that purpose. It is "Champion (brand like the plugs) Spark Plug Thread Lubricant and Anti-Seize Compound # 2612". Most aircraft supply stores sell it. A good place to get those "Remove Before Flight" red tags also.
To anti sieze
