Transmission Problems
Old Oct 4, 2004 | 08:11 PM
Upstate's Avatar
Upstate
From: [Quote=WOEII] Is dried brown doodie powders man! [/Quote]
This is pretty extensive so I am going to attempt the Cliff Note version.
All of this depends on trans model number for given PSI ranges. You should invest in a service manual, it's definitely worth it. This may not be applicable to your car. With that being said....
In P,N,OD,D; @ 1000 RPM
Depending on model Normal PSI range should be:
56-64
65-75
Full TV (@ 1000 RPM) Depending on Model:
144-185
137-172
155-196
145-184
122-155
123-154
146-186
128-164
139-179
152-197
Reverse @ 1000 RPM
92-106
108-123
Reverse@ 2000 RPM
All North of 200 PSI
First & Second @ 1000 RPM (And Full TV Apply)
191-217
162-187
163-186
These readings are to be taken from the Line Pressure Tap only, located on the drivers side of the trans.
