Breaking up, I'm breaking up!
Old Sep 11, 2004 | 01:33 PM
jerkyboy's Avatar
jerkyboy
Default Breaking up, I'm breaking up!
I can't seem to figure out why she won't rev past 6K. Zelement is having the same problem over on FI/Nitrous so I thought I'd bring the question over here. After the install of my DFI, the vette hits what seems like a rev limiter at 6000 rpm. I see black smoke trailing has I hit this point. So far, I have replaced the plugs and wires. I thought it might be the ign module because the jerk who installed the DFI claimed that he had to put in two modules to get it to rev. I put in an Accel module with the same results. Also switched out the new DUI coil for my old stocker. Same problem. It happens as revved in neutral or under load. It did not have this problem prior to the DFI installation. I don't know what in the program could cause this however. I have set the limiters to 6700. I was hoping to track it tomorrow and this problem is happening right at my power peak (6100) argggg. Any suggestions? Thanks
Old Sep 11, 2004 | 01:43 PM
NoWorries's Avatar
NoWorries
Just a thought, but which tachometer is this 6,000 rpm at? Your stock guage might be lying to you, what's the laptop say?
Black smoke means that it's killing the spark, I don't know what the DFI uses to limit the revs, anyways, we know it's not a fuel problem.
Old Sep 11, 2004 | 05:07 PM
jerkyboy's Avatar
jerkyboy
I've got an aftermarket tach and it's pretty synch'd with the reading on the laptop.
Old Sep 11, 2004 | 05:50 PM
FELNGR8's Avatar
FELNGR8
Bring it to Capitol anyway and short-shift it so I can beat you!
Old Sep 11, 2004 | 06:27 PM
comp's Avatar
comp
could it be going pig rich????
Old Sep 12, 2004 | 07:17 AM
jerkyboy's Avatar
jerkyboy
It's definitely running ruch, can't imagine it would shut down though.
FELNGR8T, I'll see you there!
Old Sep 12, 2004 | 11:31 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
valve springs
Old Sep 12, 2004 | 12:12 PM
rick lambert's Avatar
rick lambert
sounds like your floating the valves-valve springs.
Old Sep 12, 2004 | 07:34 PM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
Pig rich will put the spark out.
To Breaking up, I'm breaking up!
