Man... it hasn't been my year. After running 10.72@132 two weeks ago I was aiming for the 10.60's. I left the line hard, probably a low 1.5/60 hit second gear and there was a loud bang... then it acted like it was in neutral. Got it home, got it up in the air, and checked for damage. It broke the Dana 44 housing in half!!! I haven't torn it down yet, so I can't say for sure what exactly caused it. I have pictures if somebody can post them for me. Didn't somebody make a Dana 60 or 12 bolt centersection that was modified to replace the stock Dana 44 center section? That, or I will be backhalving the car with a 9". I am DONE with the Dana 44. Oh... and I can't go automatic trans... I have too much fun banging gears.
Sorry to hear that, Jim. That's the third time this year, I know of, it got a break on the ride home. Have you considered buying a towing company? I don't know of a viable alternatve to the Dana diff. I'll keep my ears pealed and let you know if I hear of something.
Thanks for the compliments John. I think you are right... If I had an automatic in my car the Dana would probably live. But with a ZF, and a dual disc clutch, it does shock the hell out of it. I can't see spending $1500 to $2000 to put the Dana 44 back together, and have it break again. I would rather put that money towards a rear end that won't break. Right now... I am leaning towards a Dana 60 and a 4 link. I know it's about 30 lbs heavier than a Ford 9", but it's bullet proof, and I think a Dana 60 has a coolness factor, not that a Ford 9" isn't cool. And I think over all my car will be lighter after being backhalved with a Dana 60. I will also use the deepest dish 15x10 Weld wheels with about a 2" backspace, that way I can have a narrower rear end that is stronger, a little lighter, and a little more efficiant. I will also go with a newer generation locker. I know there are some out there now that are pretty quite, and don't bang either. I have to look into that some more.
I will also have some Mark Williams chrome moly halfshafts for sale along with my 15x10 Weld wheels.
tpi 421 if you are going to the hassle and expense of backhalfing and dana 60 why would you put in a locker and not put a spool in the dana 60 also i am on other dragaracing boards and guys are grenading the lockers also just my thoughts
I still need to talk to Strange and Mark Williams about the locker. I have heard that there are lockers that would hold up to the abuse, but I need to check it out some more. I would prefer a locker if it will hold up, but if it questionable, I will go with a spool.
