Radiator Removal Instructions
Old Sep 12, 2004 | 08:16 AM
Pony_Express_Driver's Avatar
Pony_Express_Driver
Default Radiator Removal Instructions
Can anyone here scan the section of the shop manual explaining how to remove the radiator from a 92?
Old Sep 12, 2004 | 04:09 PM
bogus's Avatar
bogus
I could... but that would mean hooking the scanner up... and reinstalling the software. I am waaaay to lazy for that.
But, I can tell you about how to do it!
1) drain all the coolant
2) remove the intake assembly.
3) remove the radiator hoses.
4) remove the shroud. This is tricky. There are 2 small 7 mm screws that must be removed from the inside of the intake.
5) once the shroud is off, the rad just comes out. It is not "bolted in". It just rests on some rubber grommets.
A trick for reinstalling. You install those nasty little screws from the OUTSIDE of the shroud.
That's about it.
