A strange squeak.
Old Sep 13, 2004 | 10:16 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Default A strange squeak.
I hear this strange squeak every time I hit my breaks. Not a "brake noise" like a squeal, but a "squeak...squeak...squeak" sound that *seems* to be coming from the right rear. Is there maybe something that should be lubed on the caliper? At first I thought that it was a suspension squeak, but it really only happens under light to moderate braking. Any ideas?
Thanks,
Ed
Old Sep 14, 2004 | 01:55 PM
eschoendorff
St. Jude Donor '08
Any guesses? Anyone ever have something similar?
Old Sep 15, 2004 | 09:24 AM
LT4MOY's Avatar
LT4MOY
It might be your brake shoes. Have you had them changed recently? If not it might be your early warning sensors.
Old Sep 15, 2004 | 10:50 AM
vsocks's Avatar
vsocks
You could try brake lube on the moving parts and see if it helps.
Old Sep 15, 2004 | 02:05 PM
eschoendorff
St. Jude Donor '08
Yeah, I was thinking brake lube... but *sheepishly* I'm not sure exactly what to lube. It is definitely not the sound of the wear sensors... it sounds more like a mechanical "squeaky door" kind of squeak. If I didn't know better, I would swear that WD40 might cure the problem. I have a feeling that the pins that guide the caliper just need to be lubed, but I'm not sure how, where, or even how much to do.
To A strange squeak.
