Pulleys - How much gain?
Old Sep 16, 2004 | 11:55 AM
da6speed's Avatar
da6speed
Default Pulleys - How much gain?
I was wanting to put a underdrive pulley kit on my car(91), but was wondering how much gain would I get from this or is it even worth the hassle? Also wondering where to get a good set of pulleys? TIA
Old Sep 16, 2004 | 12:07 PM
conv90's Avatar
conv90
I don't know...
When I decided to go with this mod I noticed that it was installed by the previous owner
So I haven't data comparisions
-Beppe-
Old Sep 16, 2004 | 12:18 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I didn't measure any hp gain though the engine seems to spin up a little quicker, especially in 1st gear.
March (Summit Racing) makes a Power & Amp pulley set that includes an under drive crank and an over drive alt pulley. Though I have the powder coated steel pulleys, I think the coated Al units might give a little better results.
When you install these pulleys it's a good opportunity to also discard the frisbee from your water pump pulley.
Old Sep 16, 2004 | 12:48 PM
Wheelman's Avatar
Wheelman
I have heard an underdrive pulley set is good for around a .10 in the 1/4. When I did the march power and amp set I was suprised at the gain I felt, I wasn't expecting much at all. It seems to pull much harder thru the rpm range
Old Sep 16, 2004 | 01:10 PM
vader86's Avatar
vader86
about 10hp or so
Old Sep 16, 2004 | 10:47 PM
da6speed's Avatar
da6speed
Has anyone tried the pulleys from TPIS?
Old Sep 17, 2004 | 12:11 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Old Sep 17, 2004 | 08:59 PM
whfla's Avatar
whfla
i just installed the mach 2 pully set and i guess i noticed a little better pull at around 55 or 60 but not a bit of difference at low speeds and no difference in voltage of anything like that , all in all for the money i guess it was a good mod , it looks better anyways , plus it was easy to do !...putting royal purple in it was a better feel though !..good luck
Old Sep 17, 2004 | 11:56 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Does anyone know if there is a difference on the LT4 engine? I wasn't considering it, but good info none the less.
Old Sep 18, 2004 | 01:39 AM
redbullapril23's Avatar
redbullapril23
Could you put these in without removing anything else besides the serp belt?
damn $104 thats pretty good!!!!!
it shouldnt affect my volts too much will it?
anyone know any where cheaper?
thanks
Sean
Old Sep 20, 2004 | 03:43 PM
da6speed's Avatar
da6speed
Has anyone tried the 3 piece system with the crank, alt, and water pump pulleys? Was wondering if it affected the cooling? Thanks, Dave
Old Sep 20, 2004 | 04:03 PM
Wheelman's Avatar
Wheelman
I have the march 3 piece set. It seems to make the coolant temp rise a bit quicker when sitting in traffic at idle, but it doesnt get it hotter than normal before it levels off and goes back down quickly as soon as you start moving again so it doesnt bother me.
Old Sep 20, 2004 | 04:08 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
There was a previous thread where the member was concerned about water temp running higher than normal when in traffic. This sounds about right with the water flow slowed by the pulleys. The price is around $90 for the two pulley set from LPE http://www.lingenfelter.com/lingenfe...=18&pf%5Fid=53
Old Sep 22, 2004 | 01:16 PM
da6speed's Avatar
da6speed
Okay I bought the 2-piece set from March. Was wondering what size belt I am going to need? TIA
Old Sep 22, 2004 | 11:48 PM
da6speed's Avatar
da6speed
Does anyone here know what size belt I am going to need with the 2 pulley kit?
Old Sep 23, 2004 | 12:41 AM
scofolo's Avatar
scofolo
I need to know the belt size for the march 3 piece set please.
Old Sep 23, 2004 | 01:40 AM
hippy's Avatar
hippy
I installed a set on all the cars I have owned and have definately noticed a low end difference. The largest diff was a 2.59 car that couldn't squeal tires before to being able to do burnouts after. I have used the 3 pulley sets and have never had an overheat problem. Bang for buck I say they are a good deal. Headers rank right up there too.
To Pulleys - How much gain?
Old Sep 23, 2004 | 02:10 AM
Wheelman's Avatar
Wheelman
That was me
Old Sep 23, 2004 | 02:11 AM
Wheelman's Avatar
Wheelman
Both kits include instructions with the proper belt sizes and part numbers
Old Sep 23, 2004 | 01:23 PM
scofolo's Avatar
scofolo
