Belt Tensioner
Old Sep 16, 2004 | 06:15 PM
ZQQM's Avatar
ZQQM
Default Belt Tensioner
Any one ever replace the belt tensioner on a L98?
My 1991 L98 belt tentioner is making a lot of noise so I want to replace it myself. Any advice or direction would be appreciated.
Old Sep 16, 2004 | 06:48 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
It is pretty straightforward! Remove the belt, use a 1/2" breaker bar to put tension on the tensioner to remove the belt
Then you simply unbolt the tensioner (look at the new one first to seewhat you have to unbolt) re install and reinstall the belt
Jack
Old Sep 16, 2004 | 06:55 PM
brookman's Avatar
brookman
Who carries the tensioner?
Old Sep 16, 2004 | 07:00 PM
Kens86's Avatar
Kens86
I found it hard to get locally. NAPA, PEP Boys, Autozone do not show it as a stock item. Ended up getting it from Ecklers
Old Sep 16, 2004 | 07:07 PM
darkred91's Avatar
darkred91
I took mine off to replace the water pump it wasn't to bad but the bolt hit the cross member I had to loosen the bracket that holds the A/C compressor first and tilt it up to clear the cross member.
Old Sep 16, 2004 | 07:32 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I bought a $2 bearing.
Is your problem the bearing ?
Old Sep 16, 2004 | 09:37 PM
ZQQM's Avatar
ZQQM
Default Tensioner
Yup bad bearring. Got replacement part at NAPA for $24 bucks.
New pulley with bearing. Thanks for all the replys!
To Belt Tensioner
