1986 vette engine smoking
Old Sep 22, 2004 | 04:05 PM
85blkrose's Avatar
85blkrose
if you are worried about rings do a compression check on all cylinders.they all should be the same within approx 15lbs.
if you find a low cylinder get a squirt can with motor oil in it give a shot in the spark plug hole and if it goes up your lookin at bad rings. if it stays the same the heads need redone
Old May 22, 2012 | 12:38 AM
jj electric's Avatar
jj electric
extreme vette i had my tranny rebuilt for 500.00 on my 86 vette runs like a champ
