I really want to install a 1.6 rato roller rockers kit
Seems that a popular one is the Comp cam Pro Magnum series.
Here my question:
Self aligning or with with guideplates / hardened pushrods?
And what means 3/8" studs or 7/16" ? is the diameter of the stud for which the rocker is designed for?
The stock is 3/8" ?
if yes, to use a rocker kit with the bigger stud (7/16") I have to buy new studs and disassemble the heads from the engine to prerform the installation of new studs?
It seems that performance oriented members are with the kit with guideplates and 3/8" stud.
Why the kit with guideplates is better? (if it is )
-Beppe-
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
On the street both self-aligning and non seem to be popular and both are used with success. For hard core racing it would be 7/16", guide plates, hardened push rods, etc., no question. BTW, you do not need to remove your head to change studs if you go that route. But the stock 3/8" studs should be more than adequate for most street engines, although you may need to use slightly longer ones. I have 3/8" studs, self-aligning Pro Mags and see 6,000 RPMs with some frequency.
Your stock #113 heads have screw in studs which are 7/16" on the threaded end and 3/8" where the rockers reside. Also they have non hardened guide plates which must be removed.
So I feel it's just as easy to go with the non self aligning ProMagnums for 7/16" studs, upgrade the studs to 7/16", replace the non hardened guide plates and install hardened push rods.
The overall cost is about the same as going with self aligning RRs and the work involved with #113 heads is about the same too.
BTW, you can get all the needed parts direct from Comp. Cams. I like them even better than Summit because when Summit has stuff on back order CC may have it on the shelf.
I'm collecting parts...
I will end with complete superram 2149 Hooker LTHeaders, 219 cam, ported stock aluminium 113 heads, a chip burned by me, 52 TB, underdrive crank pulley on the engine in my sig.
..so you are saying that a self aligning 3/8" stud kit is good up to 6,000 rpm, but I need to change the stock 3/8" studs with longer ones? why?
65Z01, I like your approch...and I think that the ones NON self aligning are stronger, and since the price and the time involved is tha same I think i will go this route.
I have aquestion:
Is this tha kit you are referring? summit part CCA-1305-16?
on a warning info there is this: "Will not replace rail rockers on late model heads with centerbolt valve covers"
I have centerbolt valve covers!
Sometimes it's necessary to get enough thread contact with the poly locks to be safe. With your mod list, go with 65ZO1's advice, mine was very general.
If this where me I would get the ARP 7/16" with harded guide plates Non self alighning. You will have a stronger valvetrain that is more stable.
I have aquestion:
Yep, 1305-16 is also the Comp.Cams P/N; Summit just inserts the CCA- prefix.
Don't worry about that caution; note it refers to "...rail rockers...".
You will need to grind the valve cover drip tabs and the sides of the bolt towers to fit over the ProMags.
I intend to (eventyally) do heads & cam too which should raise my rev limit to around 6k RPM, so I bit the $$ bullet and also installed Ti retainers with 10deg locks. BTW, toss the stock tin oil shedders to further lighten the valve train.
Since you are going with the 219 cam and 1.6:1 RRs your lift will exceed .520". Are you going with a dual spring or will the newer bee-hives do the job?
I will going with 219 cam...
What I want to do is to buy Now 1.6 RR using the best kit available, KNOWING that I will insatll a performance cam.
Now I have in my garage/or on the way:
Complete 2149 Hooker LTH
Complete SR
52 TB
I will buy some stock NEW springs to use with new 1.6 RR and stock cam, and when the 219 will be on my hands I will search for the right Spring kit for the High lift new cam.
-Beppe-
I went with the non-self aligning ProMag 7/16 set up because the cost was about the same as self aligning, except I had to purchase hardened pushrods (~$100). I decided to go with the most bulletproof setup I could. I hope to add a CC 305 cam this winter, but even if I don't, my valve train would be the weak link.
I also went with the new beehive springs and Ti retainers, see my sig.
