Header gaskets & bolts question
Old Sep 17, 2004 | 04:17 PM
red95vette's Avatar
red95vette
Default Header gaskets & bolts question
I just got some Hooker comp shorties, so I'm curious whats the recommended gaskets to use, and what header bolts should I use. Could y'all please leave a link to where I can order these at a good price. Thanks.
Old Sep 17, 2004 | 04:45 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
http://store.summitracing.com/defaul...eader&x=19&y=7
Best header gaskets around
Old Sep 17, 2004 | 05:13 PM
STL94LT1's Avatar
STL94LT1
Originally Posted by flyersfan1088
I hope so, getting ready to put a set on my car this weekend.
Old Sep 17, 2004 | 06:05 PM
red95vette's Avatar
red95vette
could you send me a link for the header bolts, i'm having trouble finding them. thanks.
Old Sep 17, 2004 | 06:08 PM
STL94LT1's Avatar
STL94LT1
What type of bolts are you looking for?
Old Sep 17, 2004 | 06:15 PM
silver & red CE's Avatar
silver & red CE
I bought 3/4" header bolts, should have bought 1". Time for another JEGs order. At least they have all my CC info
Eric
Old Sep 17, 2004 | 06:21 PM
STL94LT1's Avatar
STL94LT1
3/4" bolts will work.
Good luck getting those Hooker shorties installed. they are hard to get lined up. But, it can be done, just be patient.
Old Sep 17, 2004 | 06:23 PM
CFI-EFI's Avatar
CFI-EFI
Are you having computer problems? flyersfan1088's link worked for ME.
RACE ON!!!
1MoorTym's Avatar
1MoorTym
Just something for you to consider, somebody mentioned this right after I installed mine, hope I'm in time for you.
Anyway, get hex cap bolts for the headers and it should be much easier to tighten the little suckers than traditional header bolts.
Old Sep 17, 2004 | 06:27 PM
STL94LT1's Avatar
STL94LT1
I'm going to try a set of these on my car this weekend.
Old Sep 17, 2004 | 06:28 PM
red95vette's Avatar
red95vette
CFI-EFI - HEADER BOLTS, the link was for the gaskets I'll be ordering.
IMoorTym -Do they carry the hex bolts on summits online catalog? Thanks.
Old Sep 17, 2004 | 06:33 PM
STL94LT1's Avatar
STL94LT1
Default 1" Hex Head
red95vette, if the 1" hex head header bolts that I'm going to try to use this weekend on my headers works. I'll send you a set, no charge.
Old Sep 17, 2004 | 06:38 PM
red95vette's Avatar
red95vette
Do you have an extra set or something?? I appreciate it.
Old Sep 17, 2004 | 06:42 PM
STL94LT1's Avatar
STL94LT1
The hex head bolts I am going to try aren't "header" specific bolts. But they are a high quality bolt. I can get them cheap, so if they work on my car I can get you a set. I'll let you know Sunday how they worked.
Old Sep 17, 2004 | 06:45 PM
silver & red CE
Originally Posted by STL94LT1
3/4" bolts will work....
My EM header's flanges are pretty thick and after the gaskets there's not but 3-4 threads in the aluminum heads (with the 3/4" length bolts), the 1" bolts give another 3-4 threads and make me feel better.
I like the 3/8" 12 pt bolts. I use my 1/4" drive ratchet set to torque the bolts down.
Eric
Old Sep 17, 2004 | 06:48 PM
CFI-EFI's Avatar
CFI-EFI
Did you LOOK??? Summit carries more than just header gaskets, and in more than one brand, too.
RACE ON!!!
Old Sep 18, 2004 | 03:00 AM
red95vette's Avatar
red95vette
I ordered the Percy header gasket for the chevy small block, square port. My friend reminded me LT1's are d-ports, so I was wondering if these will still fit, they look like they would.
To Header gaskets & bolts question
Old Sep 18, 2004 | 09:38 AM
STL94LT1's Avatar
STL94LT1
Default D-Port Gasket
Considering the price of Percy's header gaskets, and the difficulty installing the Hooker shorties. I would get the correct gaskets and try to do everything right the first time. You won't want to repeat the process.
Old Sep 18, 2004 | 11:42 AM
red95vette's Avatar
red95vette
Oh. that sucks. i hope summit as a return policy.
Old Sep 18, 2004 | 12:09 PM
C4Crazy787's Avatar
C4Crazy787
I used the Stage 8 system, the backside bolt on # 8 exhaust port was a pain in the azz, but the hex heads help.
http://www.digitalcorvettes.com/phot...7Stage8_Rt.JPG
The Fel Pro 1406 gasket has over 1000 miles and 16 1/4 mile runs on it.
http://www.digitalcorvettes.com/phot...7Stage8_Lt.JPG
