How To Test Heated 02 Sensor
Old Sep 19, 2004 | 02:07 PM
JAKE's Avatar
JAKE
Default How To Test Heated 02 Sensor
Is there a way to test a Bosch heated 02 sensor OFF THE CAR to see if it's good or not?
Thanks,
Jake
Old Sep 19, 2004 | 06:36 PM
JAKE's Avatar
JAKE
Can it be tested? Doesn't anyone know?
Jake
Old Sep 19, 2004 | 09:08 PM
comp's Avatar
comp
don't have a book on your car But there is a way to test for power and
get a reading
Old Sep 20, 2004 | 06:50 AM
yedister's Avatar
yedister
Jake,
The sensor must be heated to be tested , there is no chart that shows a temperature vs millivolts format.
http://www.autotap.com/articles/Unde...n_Sensors.html
yedi
Old Sep 20, 2004 | 07:26 AM
corvette90's Avatar
corvette90
try this: ( its the way i test it)
connect a voltmeter to the o2, then heat it up with a propane torch...
if you bring the measuring tip of the o2 in the outer, light blue cone of the flame, it should read low millivolts (lean) if you bring it in the dark blue cone of the flame high millivolts(rich)...
this works for me and is a rough estimate if it works or not..
on a heated o2 you can try this just letting propane from the torch on the tip ( without burning)
Old Sep 21, 2004 | 03:00 AM
JAKE's Avatar
JAKE
Originally Posted by yedister
Jake,
yedi
Thanks for the link Steve.
It told me to check the activity of the 02 from .1 to .9 mV but since the laptop died, I haven't been able to run Diacom to see what the stupid thing is doing.
Had a funky idle start all of a sudden, so I suspected it was the heated 02, so I pulled it and installed a non-heated one that I had in the garage and the idle went back to normal.
So now is suspect the heated 02 gave up the ghost, but I wanted to check it before buying another one.
Jake
Old Sep 21, 2004 | 03:04 AM
JAKE's Avatar
JAKE
Thanks for that tip.
If I use the propane trick, I'll have to send 12 volts to the 02 through the two white wires and get my DVM reading from the brown wire and ground, right?
Jake
Old Sep 21, 2004 | 09:53 AM
comp's Avatar
comp
on the link
Old Sep 23, 2004 | 01:17 PM
JAKE's Avatar
JAKE
Well, here's an update:
I attached 12 volts to the 02 and after several seconds, the tip began to heat up. After a a minute or so it became so hot I couldn't keep my finger on it.
I left it that way for a long while and the tip remained hot, so I'm convinced the heating element is working.
I then connected a volt meter to the brown wire and saw constantly changing mV readings. When I placed the flame of a cigarette lighter (outta propane) near the tip of the 02, the voltage readings began to rise. When I moved the flame away, the readings dropped.
So based on all that, I'm now almost convinced that the thing is working okay and the idle hiccup may have been caused by something else.
Idle has been fine since I swapped in an un-heated 02 that I had laying around. But just to get to the bottom of this, I plan to re-install the heated 02, check all the wiring connections again and see if the idle hiccup recurs.
Thanks for the advice; I'll post the results.
Jake
Old Sep 24, 2004 | 06:39 PM
comp's Avatar
comp
Old Sep 24, 2004 | 08:41 PM
JAKE's Avatar
JAKE
Well, now I know for sure.
Re-installed the heated 02 and checked all the connections.
Fired the engine and it seemed to idle fine, AT FIRST. then the surging began again and I got a Code 44, Lean Exhaust Mixture.
So, having run the stock UNHEATED 02 for a few days with no code or idle problem, I now know I need a new 02.
So I'm headed to O'Reilly's and AutoZone now to try to find a new heated 02, Bosch #13190..
Jake
Old Sep 25, 2004 | 06:50 AM
corvette90's Avatar
corvette90
seems like your heated o2 was poisened....o2s are very sensitive to heavy metalls, sulfur, silicia...
but maybe your experience is a pointer to my idle problem..
thanks for sharing
Old Sep 25, 2004 | 10:38 AM
JAKE's Avatar
JAKE
O'Reilly's wanted over $100 for a heated 02, which is too rich for my blood. O'Reilly's did cross-reference my part number and found out what other year/model cars the heated 02 comes on.
I found that heated 02s come on 85 GM cars with a V6 and engine code "Z", so I plan to hit the wrecking yard to see what I can come up with.
Bet I can get one for about $15.00 there.
Jake
Old Sep 25, 2004 | 10:44 AM
aklim's Avatar
aklim
Sounds like you have a failing O2 sensor. When they fail, the problem is that more often than not, thdy don't stop working. They just get "lazy" and they do move up and down but just slowly. That causes the wierd idle in your car.
I would not go with a JY unit simply because you do not know if it is in better shape than the one you have. Wouldn't a generic Bosch one work just as well and be cheaper?
To How To Test Heated 02 Sensor
