Tachometer accuracy with "tuner prom"
Old Sep 19, 2004 | 05:08 PM
WVZR-1's Avatar
WVZR-1
Default Tachometer accuracy with "tuner prom"
My ZR1 has a PROM by "SOMEONE" installed and I ran it against a TECH1 for cluster validation with temp gauges etc. The cluster tach reads about 24% high all through the RPM range. The PROM that is installed has no physical ID's and I can see the fans, cags and probably the rev limiter has been modified.
Is the tach error something that could be the result of the PROM mod? Cluster rebuilders seem to agree that tach error could be +-5% but feel this is likely a problem somewhere else. If it were a conventional ignition a filter might be a solution but on a DIS that seems not to be an option. The PROM ID on the TECH1 is 2457 which I seem not to be able to identify either.
Is there someone in the Northern Va area that could verify the prom mods or do I just need to start fresh? Do you just install a stock PROM and check for results? HELP!!!!!!!
Old Sep 19, 2004 | 09:26 PM
tjwong's Avatar
tjwong
The prom that was burned for you should not have any effect on your tach. Its signal comes from the ignition DIS module. Just as with the LT1 cars their tach signal comes from the negative side of the coil through a tach filter before going to the IP. I would tend to think that the problem is with the tach in the IP rather than anything else. It is a simple thing to remove the Instrument cluster and send it out to a AC Delco instrument shop to have it checked and calibrated.
Old Sep 20, 2004 | 08:45 PM
WVZR-1's Avatar
WVZR-1
That's kind of why I'm here, a couple cluster service reps seem to feel that there's very little likelyhood that it's a cluster problem with the 24% error and suggested looking into the prom or ecm.
I'm going to use a stock prom and validate it again against the TECH1 again. It's considerably less expensive to try the prom before removing the cluster for a checkout. There's a bit of a stumble or surge in mid RPM's with a steady throttle that maybe the stock prom would eliminate some of the diagnostics there also.
Thanks for your advice and I'll likely end up with it sent out any way!
The tach error at 24% if you did gear ratio, MPH calculations indicated that it had a pretty "stiff" gear but it didn't launch like it did. This was the initial reason for doing the validation
Old Sep 21, 2004 | 08:43 AM
Carl90's Avatar
Carl90
Sent you an email. I'm in Vienna VA and should be able to access your PROM.
I do not see any calibration factor for the tach, so I assume that a PROM change would not effect tachometer accuracy.
To Tachometer accuracy with "tuner prom"
