87 Inside Rear View Mirror Question
Old Sep 20, 2004 | 06:24 AM
Don in Vermont's Avatar
Don in Vermont
Default 87 Inside Rear View Mirror Question
Hi All,
On my 87 inside rear view mirror, does anyone know which wire in the 3 wire conductor is the Ground wire ? All the wires are black and I dont want to go further back in the wiring to locate the ground. I think it is the middle wire.
Thanks,
Don in Vermont
Old Sep 20, 2004 | 07:38 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
There should be three wires:
-Pnk/Blk is power to the switched light
-Gry is power from the dimmer switch
-Blk is common ground
All three wires go through the 3-prong connector C301, located behind the windshield header just to the left of the RV mirror.
Old Sep 20, 2004 | 09:40 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
When you look inside you will see the ground to the base of light fixture.
Thats were I tied in my ground for my radar detector
To 87 Inside Rear View Mirror Question
