exhaust system size.
Old Sep 21, 2004 | 12:03 AM
devilfish's Avatar
devilfish
Default exhaust system size.
Hello
Im going to use hooker headers, hooker front y-pipe, a strait pipe instead of the cat, then the stock rear y-pipe and finnish it off with some kind of preformance muffler ( havent decide what brand yet ).
But I start thinking that perhaps its not enough? And that I need to use dual 3 inch all the way? Se sign for my mods.
Old Sep 21, 2004 | 12:14 AM
mikey whipreck's Avatar
mikey whipreck
http://www.prestage.com/community/Te...s/default.aspx
that helped me decide on putting dual 2.5" on mine
Old Sep 21, 2004 | 12:24 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Since your headers terminate in 3" collectors it would be easiest to just go with 3" true duals, if you can find 3" input mufflers.
Old Sep 21, 2004 | 01:52 AM
devilfish's Avatar
devilfish
Hmm I dont know about "easiest", as that would force me to make a "new" dual exhaust. Instead of "just" using the hooker y pipe..
Old Sep 21, 2004 | 07:33 AM
65Z01's Avatar
65Z01
Well, a true dual exhaust would consist of separate pipes from each collector through the mufflers, right.
If you just want to use a Y-pipe setup, then for sure use 3" pipes.
You have an L98 right??
Old Sep 21, 2004 | 07:47 AM
runner140*'s Avatar
runner140*
Default Two Y-pipes?
You sort of defeat the idea of duels by going from headers into a Y pipe
then a straight pipe, then another Y pipe. Go from your headers to your pre-cats and straight through to the mufflers. 2 3/4" should do it.
Old Sep 21, 2004 | 08:02 AM
devilfish's Avatar
devilfish
I dont really have a l98 as you can se in my sign. Not much is left from my old TPI setup.
What I mean about the front y-pipe is that im NOT using the stock y-pipe but the HOOKER 3inch ypipe that fit to my hooker super comps.
Old Sep 21, 2004 | 08:16 AM
Carl90's Avatar
Carl90
I started out the route of Hooker headers and Y pipe. The Hooker Y pipe is garbage. I and other member have had problems. The headers are nice.
My current setup is Hooker headers, true 3 inch dual exhaust, Dr. Gas X pipe, Randon metallic bullet cats, and Power Effects adjustable mufflers. It is expensive, but ready to meet the my growing HP needs. In the long run, I would have save money by doing it right in the first place.
Old Sep 21, 2004 | 08:40 AM
65Z01's Avatar
65Z01
Carl90, your setup is sort of what I had in mind...true duals without the Hooker front Y.
If I'm building a moderate to high HP motor that's the setup to go with.
Old Sep 21, 2004 | 08:56 AM
comp's Avatar
comp
nice
Old Sep 21, 2004 | 01:13 PM
Carl90's Avatar
Carl90
65Z01
The Random metalic cats are small enough (3.5 inch diameter) that you have tons of flexability on where to locate them.
Also, I had an exhaust pipe bung installed for a wide-band O2 sensor, which is on order. This is the way to go, if you are optimizing your PROM fuel tables.
One other comment...use stainless steel collector bolts. I never did so much swearing in my life when I had to hack saw of the rusted bolts after 3 years of the headers being in place.
To exhaust system size.
