i just moved to utah from st. louis and was wandering how to get my performance back. the elevation here is about 6000 feet where st.louis is about 500 feet. can anybody recomend anything that would be cheap and easy to do.
I moved to Utah 2 years ago from Hawaii (sea level) and didn't experiance any noticable power/performance loss. Before moving I was concerned about the change in altitude, but was told the computer would compensate for the change and from what I can tell, it did. I haven't done the 1/4 since being here, but on the road she responds and pulls just like she always has.
From: What did the 5 fingers say to the face? SLAP!!
I bet you would be surprised to find out how much your performance has suffered if you took it to a track. Next time NHRA is running out of Denver, check out how much slower the times are. Altitude plays a huge role in times.
Thanks, I'll have to do that if they run between now and December -- I'm moving to AZ curtesy of the Air Force. I'd be curious to find out just how much a difference there is.
Utah has a strip at 6000'? Where ARE you? The air is thinner up here. The air pressure is lower. When the piston goes down the hole, there is less air pressure trying to fill the void. When you DO manage to ingest a CFM of air, it contains less oxygen per CFM. There is no way around it. You are fighting Mother Nature. Nitrous or forced induction are the only ways to make up for the altitude.
The twin turbos are the reason for YOUR experience. And I'd bet you won't run as fast at the track, here, as you did in Hawaii, but your difference would be much smaller.
Keep in mind that you have turbos as well. Since they are compressiong the air they work a lot better at altitude than a naturally aspirated motor. You do lose some power as the oxygen content is less and the turbos have to work harder to achieve the same boost.
I think NHRA adjustment for turbo cars is only 1/2 of what it is for NA cars.
i live up in park city, i was wandering do 90-91 have MAF sensors, wouldnt that change everything.
OK, YOU are at 6000", but your race track is at 4400', per NHRA, 4225' actually. The computer and all the sensors feeding it with info, adjusts the fuel to match the air. The A/F ratios will be correct for the conditions, but such equipment can't adjust the AIR. You should feel the difference in the power between home and the track.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I drove my NA Corvette to Salt Lake City last year. I live in San Diego. The car felt like it lost 50hp.
Turbos will compensate for less barometric pressure..in other words if they are set to blow off at 12 psi, they will blow off at 12psi if they are at 4000feet or at sea level...the motor always sees the same intake pressure. For this reason a turbo is THE answer to the altitude problem.
A supercharger will help but will also experience some loss of power at altitude, i.e. if you have driven the blower to provide 5psi at sea level, it will provide something less than 5psi at higher altitudes.
The good thing is that every, non-turbo car at your altitude is experiencing the same power loss.
Just a minor correction. The 12# blow off pressure is a pressure DIFFERENCE. When there is 12# MORE pressure than atmospheric, the pressure overcomes the spring pressure which is aided by the ambient air pressure, and the valve dumps the excess. With the lower pressure at higher altitudes, the boost pressure is lower, also.
would a 58mm bbk throttle body help in componsating for the loss of air through the motor. if not would a fuel pressure regulator help me if i turned down the fuel.
No and no.
The MAF and computer already do a good job of adjusting the mixture.
You have exactly the same problem as anyone who wants more power at sea level. You need to be able to run more air through your engine. If it won't help you at sea level, it won't help you at altitude.
Neither. If anything the stock TB will flow more of the thinner air than it did the good air, at lower elevations. The fuel pressure question goes back to the answers concerning the MAP and/or MAF. The sensors tell the ECM what the conditions are and it applies the proper fuel for the operating environment.
If your L98 is now bone stock, that loss is pretty easy to gain back with some simple bolt-ons.
Not at 6000'. I live in Denver and our track is at 5800' and some simple bolt on's will not get you back on track. At our altitude you lose somewhere between 17-20% on any given day. The only bolt on's that are going to give you that back are superchargers. My dad's Grand Sport dynoed at 249 uncorrected and 292 corrected for sea level. The correction that day was 17%.
