What are the fuel injector ratings for a 90 l98 i have 2 bad injectors that shorted and stop the car from running no injector pulse ohmed them out removed the inj wires and car started? maybe goin with accel injectors.
Yes, 22 lb/hr
I had the confirmatio reading my stock chip.
There is a constant where the chip say to ECM the "size" of the injector installed, so the ECM knows how many times the injectors have to stay open to feed the engine.
This constant in a stock .bin for a 90 auto is: Injector Flow Rate 22.08lbs/hr
-Beppe-
