another horn problem
Old Sep 23, 2004 | 08:25 PM
91redvette's Avatar
91redvette
5th Gear
Default another horn problem
Horn decided not to work. Horn relay clicks but no horn. Any ideas?
Old Sep 23, 2004 | 08:48 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
did you make sure the connections didn't come lose?
Old Sep 23, 2004 | 08:49 PM
Square's Avatar
Square
Did both horns work before?
When I got my 86' one didn't work at all and the other made a wheezing noise. I replaced both horns and all is well.
Old Sep 23, 2004 | 09:01 PM
Pete K's Avatar
Pete K
Check for power with a test light at the horn connector. Very possible to have 2 bad horns. If power makes it all the way to the connector swap them out. Wait till you see what they cost. Especially the "c" note horn.
Old Sep 27, 2004 | 08:40 PM
91redvette's Avatar
91redvette
5th Gear
Removed both horn connections to look for corrosion. Reconnected after visual inspection but still no sound!
Old Sep 27, 2004 | 08:43 PM
91redvette's Avatar
91redvette
5th Gear
I bought car in June and only one horn worked. I will obtain another horn to see if the problem is in the horn itself.
Thanks.
Old Sep 27, 2004 | 08:50 PM
91redvette's Avatar
91redvette
5th Gear
I will check for power as you advised.
Thanks!
To another horn problem
