Simple Question-Rear Sway Bar Size
Old Sep 24, 2004 | 11:39 AM
94Controller's Avatar
94Controller
Default Simple Question-Rear Sway Bar Size
I have a 94 coupe with the FE1 suspension. I measured the front sway bar (24mm) to order some bushings but I didn't measure the rear. Now I figure I'll order the rear at the same time, but I'm not sure of the size. I would guess 22mm...anyone able to tell me for sure, or could it be several different ones?
Old Sep 24, 2004 | 08:02 PM
MYCoupe's Avatar
MYCoupe
I also have a 94 coupe with the FE1 suspension. I measured my rear bar the other day and it was 24mm.
Old Sep 24, 2004 | 09:02 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
This ought to help.
http://corvetteactioncenter.com/tech/c4/susp_chart.html
If a 7/8" wrench fits over your rear bar pretty well, it's a 22mm. I'd bet you have a 24 though.
To Simple Question-Rear Sway Bar Size
