Air Pump Eliminator Pulley
Old Sep 24, 2004 | 03:41 PM
6spd's Avatar
6spd
Default Air Pump Eliminator Pulley
is anything i should know about before i do this any tricks or anything?? just take out the old put in the new?? i will need caps for the air tube does anyone know the size.
Old Sep 24, 2004 | 05:41 PM
90 Convertible's Avatar
90 Convertible
I did that mod when I put in my longtubes and highflow cat. I used the Dragon's Breath Performance one (supporting tuner). I was impressed with how sturdy it was built. It also cleans up the engine compartment.
Old Sep 24, 2004 | 06:37 PM
FlyboyZR1's Avatar
FlyboyZR1
Yup you can tear out the old pump and everything connected to it if you want, without throwing a code. Really cleans things up nicely. 1/2" pipe caps
Old Sep 24, 2004 | 06:43 PM
6spd's Avatar
6spd
thanks but there is a hose that goes underneath the car and comes up in front of the engine that connected to the air pump were does that go under the car?? also what size caps do i need for the dirverter valves??
Old Sep 24, 2004 | 08:29 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The tube you speak of is the air tube to cat. I removed the cat and tube so I can't comment on how to cap it. If I remember correctly, it had a check valve just like the ones at the air tubes at exhaust manifold. If thats the case than a 1/2'' npt cap will work. You can remove the diverter valves and plug the vaccum line and tie up the electrical.
To Air Pump Eliminator Pulley
