total timing
My base timing is 8deg BTDC.
If your '89 has an adjustable TPS (slotted mounting holes) youi can also tweak timing and enrichment a little by bumping the base idle value from the stock .54Vdc to the more agressive .65Vdc. This will give a crisper throttle response.
RACE ON!!!
RACE ON!!!
TPS----RPM----Speed----ADV----Ret
0.86----775------8-------27-----0
4.58---2,600-----9-------34-----1
4.72---3,523----28-------31-----2
4.70---4,488----35-------34-----1
4.72---5,200----45-------36-----0
4.72---3,750----55-------32-----0
4.72---3,710----61-------32-----1
4.72---4,370----66-------34-----3
4.72---4,550----72-------34-----5
2.56---4,870----77-------34-----4
1.09---2,680----78-------48-----2
0.78---2,730----76-------48-----1
First off it looks like it wants to start at 34deg BTDC and run about 36deg BTDC by 5k RPM but knock retard is holding it back.
CFI-EFI, you may be right about some more power in there. It looks as though I may need a new ESC module again.
BTW, I'm running 93 octane fuel, a 160 deg F T-stat and fan switch. This pass was taken in the evening with about 160deg F of coolant temp.
Is "ADV" the total spark advance? Or is it the electronic advance that gets added to the base timing? Also, "Ret" is the numbers of degrees of timing pulled out by the ESC? I find the "Ret" numbers, in the last three entries, after you backed off the throttle, intriguing. Can you be getting "false" counts? I wouldn't expect true knock with cool evening air, your water temp, and gasoline. That is why I suggested a repeat with no knock sensor. Do you still have the stock compression ratio? This is all VERY interesting.
RACE ON!!!
Yep it's stock CR; it still has stock cam & heads and not been opened up.
That's a good idea to make a run w/o the knock sensor connected.
A few years ago I was plagued by false knock counts and Gordon suggested the upgrade ESC module, which cured the problem. Since I don't know the failure mode of that module, I guess it's possible it needs to be replaced. I haven't made any mechanical changes to the engine that would account for mechanically induced false knock.
Next question. At 4370 rpm you show 34* of advance, (really 42) and 3* of retard. Does that mean the advance WOULD be 37* (actually 45*), if the ESC hadn't pulled out the 3*? Or is it 34* from the ECM, minus the 3* (31) pulled out by the ECS?
The reason I asked about the CR and the combustion chambers, is that a well built modified engine will require less advance to make max power. With the stock combustion chambers and squish area, 38-42 MAY be desirable.
If this were a mechanical advance distributor, I'd say shorten up the centrifugal advance and leave the 8* base, or maybe a little more and get it to be "all in" at 3000-3400 rpms.
I guess I'm better off not knowing what mine is doing. I've got 14* of base timing. Now you've got ME worried.
RACE ON!!!
