Not sure whats going on. Any idaes? Runs fine till temp hits 197 degrees then idles fine but under load shutters, feels like it's not running on all cyl. Back off the throttle and it's ok hit it with a load or WOT and runs like crap.........? Thanks. As you see I ended up not having to sell the beast......yeeeeeeeeeeeeeeesssssssssssss ssssss.
Does it misbehave when you rev it in park? If so clip a timing light onto the wires to see if missed flashes match with engine misses. Also check fuel pressure.
To check for a clogged cat, either open the exhaust system in front of the cat or install a pressure gauge. More than a few lbs of back pressure would indicate a problem.
