Where can I get a schreader valve?
Old Sep 25, 2004 | 10:51 PM
howdo's Avatar
howdo
Default Where can I get a schreader valve?
The schreader valve on the fuel rail on my '91 is leaking. The guys at Superior said this is a non servicable item, that I would need to replace the whole fuel rail. Is this true? Any idea where I can get a new one? It looks like it should just screw into the fuel rail.
Thanks,
Howdo
Old Sep 25, 2004 | 11:21 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You should be able to get the core at any bike shop. If it's actually leaking where it goes into the rail... well, there's a gasket made of metal & viton that you need to replace. Just head to the hardware store and find an oring that fits.
Old Sep 26, 2004 | 01:13 AM
Bruce's Avatar
Bruce
If you cannot find one, than just buy a -04AN cap from summit. I don't have athe shreader valva any more and that is what I use.
BRuce
Old Sep 26, 2004 | 02:11 AM
aklim's Avatar
aklim
Would this work?
http://www.grainger.com/Grainger/pro...793365&ccitem=
Old Sep 26, 2004 | 10:24 AM
VT Solo2's Avatar
VT Solo2
I'd just call up a Chevy dealer and see if they have the valve. I had to replace the valve in the A/C line a few months ago. I was told it was non servicable and had to buy the whole A/C line to replace it. I called up my local dealer and they had a part number for it and got it for me the next day.
Old Sep 26, 2004 | 10:43 AM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by aklim
If the 1/8th" NPT threads are correct for your fuel rail, Yes.
I don't know about the '91, but my parts book shows the valve assembly (similar to aklim's link) for '89 (as late as my book goes) and earlier TPIs. Chevy wanted $32.00 for it years ago. I was looking for a way to add a Schrader valve to my Crossfire, so I needed the whole assembly. I ended up with a tire valve assembly from K Mart for about $5.00. If yours is leaking, the tire store will probably GIVE you a new core.
RACE ON!!!
Old Sep 26, 2004 | 10:49 AM
Corvette0096's Avatar
Corvette0096
I found a place that sell them. They are for fuel rails. Said in there description.. Ready for the good part? You have to buy 100 at a time. I will get a hold of them Monday and see how much 100 cost. For the guy that are using them out of tires stems. You have a ticking time bomb there. The one that are for the fuel rail are made out of viton and the ones out of bike tires are made out of nitrile. The one for AC stuff are made out of neopreme..
Old Sep 26, 2004 | 11:01 AM
howdo's Avatar
howdo
I guess I would be a little afraid of using a non-gas valve. It might be ok, but I wouldn't want to take a chance. Years ago, when I was young and green, my '86 mustang gt burned up real good due to a carb fuel leak.
I'll try the dealer again.
Thanks for all the responses.
Howdo
Old Sep 26, 2004 | 11:57 AM
tjwong's Avatar
tjwong
Did you call NAPA? If I remember right they have them in their ECHLIN fuel and carb parts line.
Old Sep 26, 2004 | 01:27 PM
Corvette0096
Nothing..
Old Sep 26, 2004 | 01:57 PM
CFI-EFI's Avatar
CFI-EFI
Mine has been "ticking" for about 4 years, now. Initially, I was concerned, but with no intelligent input, I just decided to "go for it". No problems, yet. Good info. Where were you 4 years ago?
RACE ON!!!
Old Sep 26, 2004 | 02:22 PM
aklim's Avatar
aklim
I believe for the grainger one I had to buy 6 and it was around 12 dollars or something like that. You just need a commercial account. That was what happened last time I bought it for my car. I then proceeded to sell the rest of the 5
Old Sep 26, 2004 | 02:38 PM
SunCr's Avatar
SunCr
Bought a replacement (it's the complete valve which just threads into the rail) at a Dealer. Otherwise, Street & Performance - www.hotrodlane.cc - probably has it along with all the other rail parts should you want to rebuilt the rail.
Old Sep 26, 2004 | 03:45 PM
scorp508's Avatar
scorp508
Its only going to take 1 time for one not made for fuel to fail and send a car up in flames. I wouldn't take the risk.
Old Sep 26, 2004 | 05:38 PM
LD85's Avatar
LD85
I got mine from a NAPA, it is used in an AC valve application, fit perfectly
Old Sep 26, 2004 | 10:10 PM
Corvette0096
They will fit fine. Just over time the gas will eat the stuff that they are made of.
Old Sep 27, 2004 | 12:59 AM
comp's Avatar
comp
YEP...the one's for AC are different...THE spring one for a tire will work in a pinch
To Where can I get a schreader valve?
Old Sep 28, 2004 | 09:39 PM
dizwiz24's Avatar
dizwiz24
Go to a junk yard.
Any GM MPFI engine has the same one. I got mine off a V6 camaro for $5
Dave
Old Sep 28, 2004 | 09:54 PM
Kenwood's Avatar
Kenwood
Go back to the dealer .>>>>Lie say I need the schrader valve for a 1997 corvette/camaro/trans am whatever ..
he will hand you the same thing you have except it will be a black fitting with a plastic cap... Thats whats on mine right now..I dont know why GM changed the Flipping part number just because they are now black instead of silver... His system if he was smart enough to use it properly would have shown the ls1 version as a replacement..
Old Sep 29, 2004 | 02:11 AM
Corvette0096
Thanks,
Howdo
How many you need?
http://forums.corvetteforum.com/showthread.php?t=913136
