Coil-over install question
Old Sep 26, 2004 | 06:32 AM
Vetteboy77au's Avatar
Vetteboy77au
Default Coil-over install question
Hi everyone....
I have noticed that most people putting coil overs on are installing in around 1988+ cars... I remember reading people talking about changing shock tower...
So:
1) On a 1986 couple, can I simply remove my upper/lower control arms and replace them with later model ones
2) Is there any difference in cross-members in the C4's...ie. Can I bolt a newer shock tower up to my 86?
Thanks in advance.
Old Sep 26, 2004 | 12:58 PM
Mo_Bandy's Avatar
Mo_Bandy
Vetteboy,
On my 96 I only had to open up tower to keep the springs from rubbing.
I like you, have read about some folks moding the earlier C4 shocktowers.
I believe what they did was take them to a weld shop and just had them reinforced. Mine have been fine with almost 2 years of use and drriving cross the USA twice over some pretty harsh roads.
good luck, you'll enjoy the difference...
mo
Old Sep 26, 2004 | 09:17 PM
VanSpeed's Avatar
VanSpeed
There may be direct bolt in kits for the early C4's (84-87) now, I don't know for sure though. However, I have read a few tech articles in some of the Corvette magazines that detailed the install of coil over's on C4's. They all indicate that the early C4 (84-87) shock towers are to narrow for the coil over setup. They indicated it was necessary to replace the shock towers with ones form later C4's (89-96 apparently there is something unique about 88's). As stated by Mo_Bandy it is still necessary to open up the shock towers on the later C4's for clearance for the coil spring. I have read some post where people have added additional material to the shock towers for stiffening, but that does not seem to be required.
Brian
To Coil-over install question
