Base Timing settings
Old Sep 27, 2004 | 07:46 PM
mean8t's Avatar
mean8t
Default Base Timing settings
What would be a good initial base timing setting for an 85 TPI 350 w/ vortec heads, 9.8:1 CR, 224*/230* .510"/.512" cam, headers, and high flow runners. I have heard that base timing is related to cam duration and obviously CR. What is the stock base timing for an 85.
Thanks.
Old Sep 27, 2004 | 08:02 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I believe 6deg BTDC is stock base; give it what it wants without ping.
CR and duration are factors but it's realy effective CR which depends on static CR and overlap (duration & LSA).
Old Sep 27, 2004 | 08:42 PM
CFI-EFI's Avatar
CFI-EFI
I think the base timing on all L83s and L98s is 6*. Your best bet is to expeiment. Make a series of 1/4 mile passes, and keep advancing it until your mph quits improving.
Old Sep 28, 2004 | 05:47 PM
mean8t's Avatar
mean8t
When you say give it what it wants without ping, what so you mean? Give it timing until it pings then back it off, what about the advance curve? I don't have any diagnostic software to watch the computer, so should I drive it without the knock sensor to hear if the thing knocks?
Old Sep 28, 2004 | 08:22 PM
CFI-EFI's Avatar
CFI-EFI
That's the beauty if the 1/4 mile merhod. When it knocks, whether you hear it or not, the ESC will pull timing to "save" the engine, and THAT will slow your 1/4 mile mph down. Back it off 2* and your good to go.
RACE ON!!!
To Base Timing settings
