? about stealth ram..
Old Sep 27, 2004 | 10:56 PM
Hippiehead025's Avatar
Hippiehead025
Default ? about stealth ram..
sincei t has no EGR provisions, you cant hook up the AIR tubes form the manifolds or headers to this manifold correct? So when i goto buy my headers just get non emissions ones? I wouldnt need emissions headersanyway correct? because of Supercharger eliminates smog pump...?
Old Sep 28, 2004 | 12:22 AM
tjwong's Avatar
tjwong
Thats pretty much right, but a Holley stealth ram will not fit under the stock hood of a C4. Also a supercharger does not necessarily do away with the smog pump as most of these kits are smog legal, and being that they keep all smog devices active.
Old Sep 28, 2004 | 05:16 PM
Hippiehead025
the procharger kit eliminates it but sumhow has sumthin esle into it tht works like a SP? dunno....and ima get a custom plenum made.
Old Oct 1, 2004 | 09:19 PM
doug_dayson's Avatar
doug_dayson
ATI's L98 Kit uses the Supercharger's discharge to replace the OEM AIR Pump.
LT1's had an Electric Smog AIR Pump I believe, which doesn't get replaced.
LT4's had no AIR Pump...
Doug
To ? about stealth ram..
