ZF6 Tranny Question
Old Sep 28, 2004 | 10:20 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Default ZF6 Tranny Question
My ZF6 is getting worse... the syncros are going and 3rd is grinding worse and worse lately..
I have seen some NEW ZF6 trannies on ebay for around $2000-$2500, but they say they are for ZR1's LT1's and LT4's and stuff.
My question is: Is this the SAME transmission as in my '89? or is the ZF6 different for the other cars?
I will most likely be purchasing a new one or rebuilding the old one in the next year, but I am starting to shop now.
Old Sep 28, 2004 | 10:27 AM
ASRoff's Avatar
ASRoff
You have a "Black tag" ZF-6 speed They are a little stronger but more louder than the "Blue tag" ZF's Eather will work. The only thing you cant use is a ZR-1 ZF they have longer input shafts. (the ZR-1 shaft is around 6 inches and the LT/ L98 series are about 5 1/2 inches if I rember correctly.
Old Sep 28, 2004 | 12:01 PM
GIJoe's Avatar
GIJoe
ahh ok... so i should be safe with any of the "lt1/lt4" ZF trannies, just NOT a ZR1 correct?
Old Sep 28, 2004 | 12:05 PM
Gary04Z06's Avatar
Gary04Z06
You might call http://zfdoc.com/ to see about getting it fixed first.
Old Sep 28, 2004 | 12:52 PM
ASRoff's Avatar
ASRoff
Correct,
The main diffrence between the black tag and Blue tag is Black is rated at 450ftlbs and the blue is at 400ftlbs.
ZF docs and white racing charge about 2500 for a basic rebuild. The main reason is because the only company that makes bearings for our trans is ZF they charge $700 for just the bearings! that doesent include syncros, gears, shafts or shift forks if needed.
If you can find a new trans for $2,000. you are way ahead!
If you want a seriously beefed up gear box ZF doc's will cryo all the parts and weld 2nd gear to the shaft. A very stout box.
By the way I bought a Brand new ZF this past July for $1600.
Old Sep 28, 2004 | 06:43 PM
1MoorTym's Avatar
1MoorTym
Try them -
http://www.rsgear.com/
Old Sep 28, 2004 | 07:47 PM
mxw1's Avatar
mxw1
Default Checked Fluid Level?
Check your clutch fluid level. Leading cause of wear on synchros and hard shifting.
Old Sep 28, 2004 | 09:58 PM
chaos on wheels's Avatar
chaos on wheels
I agree!
Old Sep 28, 2004 | 11:56 PM
froggy47's Avatar
froggy47
I'd try a new master & slave first if they are original. $200. of parts. I did my slave last weekend & improved shifting very noticably. I'm doing the master next.
55k miles on mine.
Old Sep 29, 2004 | 07:37 AM
RichS's Avatar
RichS
Originally Posted by 1MoorTym
I bought a new one from them in April. They advertise $2800 now in some mags.
Old Sep 29, 2004 | 01:24 PM
bogus's Avatar
bogus
I contacted Bill at www.zfdoc.com for a rebuild estimate - his special superduper rebuild is 2800.00. It is VERY thorough.
Old Sep 29, 2004 | 08:26 PM
LD85's Avatar
LD85
brand new ZF
www.gmpartsdirect.com
$1800 + shipping
Larry,
I tried to send you the article on 4+3 conversion.
Did you receive any of it?
To go through a working ZF S6-40 would be:
Labor - $900
Rebuild kit - $100
Synchronizer Kit - $500
Bearing Kit (if needed) - $600
Misc. shifter components - $75 to $250 if adding a short-shift lever
Additional parts may be required upon internal inspection of transmission (this is the part that usually shocks the customer the most).
Bill Boudreau
ZR51 Performance
Sent: Monday, June 28, 2004 11:47 AM
To: billb@zfdoc.com
Subject: RE: 4+3
Hey Bill:
What is the cost for you to go thru a working ZF, 1992?
Still $2800?
Regards,
Larry Dickey
INDY
Sent: Thursday, June 17, 2004 2:38 PM
To: 'Larry Dickey'
Subject: RE: 4+3
Larry,
The other items that you will need are covered in the article that I have attached.
Bill Boudreau
Sent: Wednesday, June 16, 2004 7:16 AM
To: billb@zfdoc.com
Subject: RE: 4+3
Hey Bill:
If I got to the ZF, can it handle 405RWTQ and what else is needed to do the swap, can I use my flywheel etc?
Larry Dickey
INDY
Sent: Monday, June 14, 2004 9:17 PM
To: 'Larry Dickey'
Subject: RE: 4+3
Hi Larry,
Sorry it took so long to reply, been very busy lately which is a good thing.
GM is clearing out the last of their ZF S6-40 transmissions from inventory.
If you are at all serious about converting over to the ZF S6-40, I strongly recommend that you contact your local GM Parts
Department and purchase one of these transmissions a.s.a.p. P/N 12455189 (ZF S6-40 540Nm).
It has been 4 weeks since the GM’s clearance price sale began and from what I’ve heard, there are currently less than 70 of 400 units left in stock.
GM is selling these units to the dealer for an incredibly low price of $1800 new complete with shifter. That is $2800 less than what they normally sell for.
Converting your 4+3 to a ZF S6-40 is the best way to go.
Regards,
Bill Boudreau
ZR51 Performance
Cave Creek, AZ
(602) 319-6575
Old Sep 30, 2004 | 04:09 PM
GIJoe's Avatar
GIJoe
woah... thanks guys...
Hrmm i think ill give GM a call and see if they have any on clearance then LOL
if not, ill give the ZF dude a call about the super duper beefing up thing...
Old Sep 30, 2004 | 04:22 PM
GIJoe's Avatar
GIJoe
Originally Posted by ld85
brand new ZF
$1800 + shipping
What is the part number for this? I couldn't locate one and their website sucks for searching.
pablocruise's Avatar
pablocruise
The later 93+ versions will have a smaller O.D. input shaft, and thus will require the smaller throw out bearing. No big deal.
Old Sep 30, 2004 | 08:05 PM
LD85's Avatar
LD85
its in the post above
# 12455189
Old Oct 4, 2004 | 05:54 AM
larryfs's Avatar
larryfs
that rsgear place in NY is becoming popular. my friend just had his Z06 tranny rebuilt there.
To ZF6 Tranny Question
