ZF:How much power?
Old Sep 29, 2004 | 03:12 AM
Juddclot's Avatar
Juddclot
Default ZF:How much power?
I'm a little leary of pushing my '92 to hard. After reading that the ZF is limited to 450ft/lbs. What kind of number are you guys pushing through a ZF with success & durability?
Old Sep 29, 2004 | 03:35 AM
comp's Avatar
comp
are you close to stock???
Old Sep 29, 2004 | 03:37 AM
SLOWRIDE's Avatar
SLOWRIDE
If you worry too much you will not have any fun!(JMO)
Old Sep 29, 2004 | 08:36 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Ask the ZR1 guys...the 415 strokers are laying down 500+rwhp with no problem.
Old Sep 29, 2004 | 11:55 AM
jburnett's Avatar
jburnett
I ran 9.90's with mine leaving at 5500 on a clutch dump. It was behind a juiced 396" small block that made in excess of 800 lb/ft of torque on the button. The ZF is a brutally strong transmission (many consider it to be the strongest manual ever put in a production vehicle); you have nothing to worry about until you're well over 700 lb/ft of torque.
-Jeb
Old Sep 29, 2004 | 12:14 PM
aeronautica86's Avatar
aeronautica86
and you spun for how long???
seriously though, your car sounds schweet
Old Sep 29, 2004 | 12:36 PM
ASRoff's Avatar
ASRoff
The
ZF is very strong just dont miss to many shifts. you have to remember that when these trannys are rated there is a safety factor built in (usually 25 to 30%) . ZF's are so strong that Ford chose to put them behind their F-250/350/450 and 550 trucks. I cant rember who races it but there is a 8 second ZR-1 that uses a ZF trans.
They are very expensive to fix. The weak link is the hydraulic clutch setup If you go to the ZF Doc's website you will see a slave cylinder that was cut open to show a large rust pocket. The other problem is that second gear is interferance fit to the shaft, ZF docs weld it on. They also Cryo the parts.
Old Sep 29, 2004 | 12:53 PM
Juddclot's Avatar
Juddclot
Thanks for all the input guys. Yeah my car is a fairly stout 383ci w/N20. Last year on the LT4 hot cam and a 100 shot it put down 475hp/620ftlbs.
You can see how starving the car is for air. Us high altitude guys are at such a disadvantage.
Next time I'll go to the dyno it will have these parts in addition;
Comp Cams Custom Grind .565/.575 234/242 114 LSA
Comp Cams 941 Valvesprings
Titanium Spring Retainers
Comp Cams "R" lifters
Canton 6qt Oil Pan
Canton Oil Pickup
Mallory Hyfire VI (685)
Keyed Hub
Lots of head/Intake manifold porting
Long Tubes 1 7/8" (rather than the edelbrock shorties)
X-pipe (rather than the stock resonator)
150 shot of N20 (rather than a 100 shot)
You can check out the whole setup here
Hoping for 550+whp on the spray. I'm afraid that I'll also be pushing 700ft/lbs (160% of the GM stated limit). I really can't afford to spent 2+K if the tranny goes. I'm going to have to look into the ZF docs.
Old Sep 29, 2004 | 06:28 PM
tpi 421 vette's Avatar
tpi 421 vette
I have been running 10.70's with low 1.5/60's and never had any problems with the stock ZF. This year I have broke 3 halfshafts and a Dana 44 case though
Old Sep 29, 2004 | 09:47 PM
LD85's Avatar
LD85
Only 405RWTQ
To ZF:How much power?
