94 brake experts, Help please
Old Sep 29, 2004 | 09:13 PM
CF6873's Avatar
CF6873
Default 94 brake experts, Help please
I just installed the bias spring and put it back together. I had brakes but a little spongy. I started to bleed them,(using a mity vac) and starting with the R rear.I got just a little air out of it. While bleeding the L rear I was getting a few bubbles also when suddenly I got a massive amount of air. So much that I lost vacuum in the mity vac pump.I pumped more vacuum and got some fluid and then another large amount of air like before. The master cyl never ran out of fluid,but now I have no pedal at all and get the BRAKE light on the dash as well as ABS and ASR lights. Any help on what to try next would be greatly appreciated. Craig
