Lube O-rings?
Old Sep 30, 2004 | 11:53 PM
lusthog's Avatar
lusthog
Default Lube O-rings?
I have to replace the suction line/hose on my 88's A/c between accumulator and evaporator. Finally found lilne and o-rings. Here's the question...do the o-rings need to be lubed? If so what to use? Vaseline, dielectric grease, light coat of motor oil? What won't attack the rubber o-rings. Thanks in advance for any advice.
Charlie
Old Sep 30, 2004 | 11:54 PM
chriswtx's Avatar
chriswtx
Use a silcone grease.
Old Oct 1, 2004 | 04:57 AM
larryfs's Avatar
larryfs
I believe those o-rings are special type made for a/c. you'd should check it out... and let me know
Old Oct 1, 2004 | 07:49 AM
lusthog's Avatar
lusthog
Yes, got them from local dealer. I don't have the p/n handy right now. I just figured they needed to be lubed and didn't know what was the proper lube that wouldn't degrade the o-ring material.
Old Oct 1, 2004 | 08:13 AM
comp's Avatar
comp
same as what's in system
To Lube O-rings?
