brake probs
Old Oct 1, 2004 | 04:02 PM
Clemson Vette's Avatar
Clemson Vette
Default brake probs
hey i just changed my front pads. got some pfc from autozone. they didnt have the z rated ones so i got the carbon metallic ones. i compressed the caliper pistons with a clamp then put the new pads on. now i have a pedal. i can drive it but it's not near as touchy as it used to be. i bled the brakes and still soft. the fluid is really hot too. i went and drove it hard and the abs would hardly come on. almost had to stop to come on. so am i just ok and got some crappier pads or what? please help me out cause i gotta race tomorrow and need this thing to stop.
stuart
Old Oct 1, 2004 | 04:07 PM
bogus's Avatar
bogus
it will stop.
you see, most factory pads are designed to stop quick, when cold, then fade like the dickens.
I have found that my NAPA ceramix are very soft when cold, but still bite good when hotter.
what fluid are you using? I recommend Valvoline Synpower. Great stuff for the money.
there is a chance you still have some air in the system, too... but I doubt it, unless you let the master run dry.
Old Oct 1, 2004 | 04:12 PM
383LPE's Avatar
383LPE
did you bed the pads? also like bogus said they work better warm/hot.
Old Oct 1, 2004 | 07:05 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
stuart
Hi
You use the words "touchy" and "soft"
By "touchy" do you mean you got an instantaneous, noticeable response from your old pads at the time(moment you pressed on the pedal)?
By "soft" do you mean the pedal is not "firm" at the point where brakes are being applied?
The "touchy" could very well be the composition of the new pads vs your old pads, There are big differences! It could also be, as someone pointed out, a need to "bed the pads" Various suggested ways to do this!
If the pedal is "soft" when brakes are applied then somehow you must have gotten air in the system! Only soloution is a full system bleed till the air is gone
Jack
To brake probs
