Rear Wheel Bearings- which brand
gang,
I know this horse has already been flogged before but I need some info pertaining to rear wheel bearings.
I need to replace one on my 91 and thus far have found the following brands:
AC Delco- very expensive
Chicago Rawhide- from Advance Auto
Timken- from Autozone
Napa- can not find the bearing on their site- anyone know a part
number & price?
I am not near a Pep Boys- so that one is out.
My questions is which one is ok to use a street driven car that has 315s' (my car is a ZR1) on the rear? Is the AC Delco bearing a repackaged Timken (for example) bearing?
Any help is appreciated.
Dan
number & price?
Dan
Originally Posted by RedZR
gang,
My local NAPA quoted me an SKF for $199. The Timken at Autozone was $149. I forgot to ask the warranty at Autozone. The Pepboys is supposed to be SKF too. I dug up the archives and there have been debates on the correct bearing. Supposedly the Pepboys one is, but there are also many early failures using them. I need one too and don't know what to do. I found this on e-bay:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Supposedly OEM by the listing, but they say it is made by Precision. The wheel studs don't look right eigher. I'm leary.
I would go with the AC Delco or Napa. Never again will I buy from an unknown company. I went through two bearings after two runs at the track. I now have one Napa and one AC Delco and can smoke the tires at the track all day long. With the after market bearings I was fortunate to get my car home.
I've had $99ea from Pepboys in for about 3 years and over 50,000 miles and they are still tight. I check them with a dial indicator. From the posts I've read their are only a few companies making the bearings and the most any you get are OEM re-boxed.
However, mine have a lifetime warranty and I would look for the best warranty I could get.
JS
JS
Dan
Dan
RACE ON!!!
I went the PepBoys route and picked one up today. $161, lifetime warranty. I found the NDH stamp on the bearing ring. It looks good to me, and a lot better than the one that got wiped out by a failed spindle.
Scorp: where did you find this spec? My 93 service manual makes no distinction between trans, and just says 164 ftlb.
Originally Posted by scorp508
When you install the new one torque the 36mm nut to;
166 ft/lb : Auto tranny
200 ft/lb : Stick tranny
