Question for those using magnetic drain plugs.
Old Oct 3, 2004 | 05:26 PM
MaddMaxx's Avatar
MaddMaxx
Default Question for those using magnetic drain plugs.
How much material are you seeing when changing the oil?
Old Oct 3, 2004 | 05:56 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default none
running mobil 1...so far so good...nothing ever showing
Old Oct 3, 2004 | 06:19 PM
ericcer's Avatar
ericcer
I had a tad from my new engine on the first change. I could send you a picture if you like.
Old Oct 3, 2004 | 06:30 PM
Red Tornado's Avatar
Red Tornado
a miniscule amount of practically nothing on the first oil change after engine rebuild/modification, 3 changes so far: 300, 600 and 1000 miles. I saw almost zero on the last two changes. perhaps there will be a bit more now that I'm in the 3000 mile interval period.
Old Oct 3, 2004 | 06:39 PM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
Unless you have a very abused engine, you should not see much more than dust.
The filter actually catches it all. Cut apart your old filter and inspect that if you want to really have a handle on what your engine is doing.
The magnets are a nice aftermarket "peace of mind" item.
If you have tons of material showing up on the magnets, then your filter appreciates the assistance..
not going to hurt anything by having the magnetic plug and the magnet on the pan at all.
Rain
Old Oct 3, 2004 | 08:07 PM
SLOWRIDE's Avatar
SLOWRIDE
I use mobil one and mobil one filter! I change oil ever 3000 miles and nothing on magnett so far.
Old Oct 3, 2004 | 08:17 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Same here. Oill changes at 150, 1,200 and 3,500 after rebuild w/ nothing but the lightest smattering of dust. For a few bucks, the magnetic oil plug can be just one more way to detect a problem before a castastrophic event occurs. No guarantee but one more possible harbinger.
Old Oct 3, 2004 | 08:30 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Using mag plug logic from the avaition industry; there will be an accumulation of "fuzz" from normal wear and tear. Some mfgrs use the rate of fuzz growth by measuring the diameter and charting growth rate.
I "read" my mag plug to guage and collect particles indicating a substantial problem. During each oil change I note the amount of fuzz and wipe the plug clean. Should the plug pickup bits or chunks, I know that its time to inspect.
So, fuzz is normal, chunks are bad.....
-JRC-
Old Oct 3, 2004 | 09:00 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
I bought the little combo package from MAD with the drain plug and filter magnet. So far no fuzz on drain plug with 2 oil changes. Maybe it's all held in the filter if there is any, as it's a larger more powerful magnet. Im hopeing there just isn't any.
Old Oct 3, 2004 | 09:09 PM
scorp508's Avatar
scorp508
A small amount of magnetic sludge covering the magnet, nothing big when I was running my original short block. When I put in the new bearings and piston I had some "break in" flakes, but nothing out of the ordinary. I'm back to just the little bit of sludge now.
Old Oct 4, 2004 | 09:01 AM
runner140*'s Avatar
runner140*
Default Magnetic oil plug
It sounds better than they are. If you change oil as often as most of us and use Mobil 1 you probably don't have any metal shavings in your oil. Between synthetic oil and a good filter, you don't need it.
Old Oct 4, 2004 | 09:05 AM
scorp508's Avatar
scorp508
I run Mobil 1 SuperSyn and the M1-202 filter (well.... right up until it was canned, now I use K&N) and I still had particles.
Old Oct 4, 2004 | 10:05 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
I always have a very small amount of fuzz on it. Very small.
To Question for those using magnetic drain plugs.
