New Clutch problems
Old Oct 4, 2004 | 06:20 AM
Getsom's Avatar
Getsom
Default New Clutch problems
Hi All,
l have just installed a McLeod twin plate clutch, in my 1990 vett and have run into a bit of a problem, getting the car into reverse gear l can only select reverse if the engine is shut down. All the forward gear change all right but are not very smooth.
l am going to replace the master cyclinder tomorrow, and put a larger after market on, l hope to get a bit more throw in the clutch, does any one have any other points l should look at if this doesn't work,(the slave cyclinder is standard).
Also whats the best type of oil to run in the box, l have been told to fill it with half gear oil and auto trans fluid?
Thanks for any help
Later Getsom Australia
Old Oct 4, 2004 | 08:31 AM
LD85's Avatar
LD85
Where can you get a stronger slave?
Lube Capacity ~ 2.2 Quarts
(engine type oil P/N 1052931 or
BMW P/N 07510009420)
www.zfdoc.com
Old Oct 4, 2004 | 08:35 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
zfdoc sells a fulcrum ball that he machines custom for the twin disk setup.
Old Oct 4, 2004 | 10:02 AM
89vette's Avatar
89vette
I had the same problem with my SPEC Stage II. Now that it is worn in, it goes into gear just fine.
Old Oct 4, 2004 | 10:14 AM
Red Tornado's Avatar
Red Tornado
sounds similar in a way to my experience after a new clutch & flywheel was installed.....could shift it in reverse, but moving in reverse was a bit shaky......condition was eliminated after break-in, about 200 miles.
To New Clutch problems
