can someone answer this please
Old Oct 3, 2004 | 08:02 PM
6spd's Avatar
6spd
Default can someone answer this please
what are the chances that if i take off the egr tube that goes to the manifold to the header i will get a code?? i will be leaving the egr valve on and hooked up till i change the manifold. these are tpis headers and it is a 91 vette. thanks
Old Oct 3, 2004 | 08:04 PM
ZF Six's Avatar
ZF Six
I believe you have to get the egr code removed from the computer when you remove the valve, that said... you will probably get a code.
Old Oct 3, 2004 | 10:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You can have the EPROM burned to turn off the EGR function.
If you run a 160deg T-stat it's quite likely that the ECM will never open the EGR valve to cool the combustion chambers so it would not detect that the system had been removed.
Old Oct 3, 2004 | 11:38 PM
6spd's Avatar
6spd
yes i have a 160 stat and the chip was done too so i'm okay them???
Old Oct 4, 2004 | 12:54 AM
Trog's Avatar
Trog
My code just set again the other day & I've had it both with & without the EGR control connected while having the tube from my headers blocked off.
Luckily I've got that aftermaket chip on the way from a fellow forum member w/ the code disabled. I freakin hate it when cruising along at 65-70 on the freeway & that damn light goes on....
To can someone answer this please
