Single Mass Flywheel Conversion gurus
Old Oct 6, 2004 | 09:53 AM
Swirk's Avatar
Swirk
Default Single Mass Flywheel Conversion gurus
I know this has been beat to death, but I can't find any answers.
Has anyone replaced their dual mass flywheel with a single mass flywheel and used the stock disc and PP? What was the noise level at idle with clutch out?
I bought a single mass from another forum member and a stage 2, Camaro strung clutch disc from SLP. My problem is that the disc is too large to fit inside the flywheel "pocket". My old disc fits with no issues.
Anyone else have this issue?
Also, it seems that my single mass is not as wide (thick) as the dual mass. Will using the ZR1 pivot stud rectify this?
Thanks as usual.
Old Oct 6, 2004 | 12:20 PM
bogus's Avatar
bogus
huh? That makes no sense.
When doing this conversion, the Camaro sprung hub is the one we use.
The old disk will fit... but I would never use it... the bite would be killer!!!!!!!! Nothing would be present to accept the drive line shocks. Damn... that would be interesting, but very touchy.
The SM is thinner... I wonder where that flywheel came from? Cause, again, we use the Fbody SMF on these conversions, with a corvette pressure plate. The SMF needs to be cut .090 to match the measurements of the DMF.
Also, make sure you "match balance" the SMF. Take it to a machine shop, where they can determine the amt of weight thats needed to keep them both on the same plane, so to speak. This way, you won't have any vibrations.
Old Oct 6, 2004 | 12:47 PM
Swirk's Avatar
Swirk
The SMF is at the machine shop being match balanced as we speak.
The center of the flywheel is 6" wide and the spring section of the clutch disc is 6 1/8" wide. I could have the center of the flywheel cut down, but I don't want to sacrifice strength.
The clutch disc is a stage 2 SLP disc. The flywheel is made by SSG Engineering. http://www.ssgperf.com/ (their webpage isn't very good).
I was going to use the stock PP and throwout.
Old Oct 6, 2004 | 12:59 PM
bogus's Avatar
bogus
Contact SLP... find out if they require some machining or a custom flywheel for that friction disk!
Old Oct 6, 2004 | 01:43 PM
HammerDown's Avatar
HammerDown
Is the flywheel a Fidanza aluminum unit, or are we talking about a steel F-body flywheel?
I have the Fidanza on my car, and yes the center section is thinner, but the outer portion is still the same thickness as the stock flywheel. That is, the clutch engagement point should be the same. The thinner center section will require that you buy shorter crank bolts, though.
Sounds like you have the wrong clutch disk.
Old Oct 6, 2004 | 03:09 PM
Swirk's Avatar
Swirk
I am sending the disc back to SLP. They said that I could have that problem.
So I guess I am in the market for a disc and PP. I have heard of RAM, Spec, Carolina Clutch and Centerforce.
Anyone know of any good deals for a new disc, PP and T/O bearing.
Old Oct 6, 2004 | 05:04 PM
HammerDown's Avatar
HammerDown
You could use your stock pressure plate, if it is relatively new and doesn't show much sign of wear. Otherwise, I'd give Tom a call at Carolina Clutch and order one from him.
Old Oct 6, 2004 | 06:44 PM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Thanks as usual.
I have a 90 Corvette with (black tag ZF - the noisier ones) and F-body single mass with OEM (ie: unsprung) clutch and pressure plate. It works fine. You can hear the tranny loud and clear inside and outside of the car. People notice the tranny noise, especially with a stock (ie: quiet) exhaust. I also get noise in the gears under part throttle (up to somewhere like 2500rpms), you get used to it but if you like a quiet car I would advise against this setup. If you have the option to get a sprung clutch disc I would advise it for the sake of making the setup quieter.
No issues with the stock pivot stud or clutch fork here. I did need different (shorter) flywheel bolts though.
Hope this helps.
Old Oct 6, 2004 | 08:13 PM
Red Rocket's Avatar
Red Rocket
Your right this subject has been beat to death.
Recently changed out my Camaro, GM, flywheel, Mcleod Camaro disc, and Mcleod Corvette Pressure plate in my 396 LT1.
The new set up is a brand new GM Camaro flywheel and Mcleod's new stage 3 disc, Bronze Pucks/Ceramic, and Corvette PP. Did not turn the flywheel .090 to fit this time. Shop welded .130 on the PP throw out bearing to fit. Clutch really grabs and has less noise than previous set up and meets spec of the factory flywheel.
Old Oct 6, 2004 | 10:31 PM
CYLT4's Avatar
CYLT4
i just finished converting to a aluminum fidanza flywheel with a stage 2 kevlar sprung disk and new pressure plate. the noise at idle is mild no big deal just a slight rattle, however the gear noise at various rpms sounds terrible. it sounds like the tranny is about to tear to pieces. i have been told that different cars have different noise levels. my car just happens to be real noisy. its a lt4 car with 36000 miles. then my second problem is i did not have the flywheel balanced to the old dual mass so i have a pretty good vibration above 3000 rpm. the flywheel must come out to go get balanced so i am going to take the new clutch and aluminum flywheel (about 200 miles on the setup) out of the car and put the dual mass and oe clutch back in. i do not like the added noise that my car makes. anyone want a good deal on a very slightly used clutch and fidanza flywheel? make me an offer.
Old Oct 7, 2004 | 07:27 AM
RichS's Avatar
RichS
I'm using a Centerforce SM flywheel and Dual friction clutch kit. Working good so far
Old Oct 7, 2004 | 11:15 AM
LD85's Avatar
LD85
Same here, Centerforce Single Mass Conversion FW and stock PP with McLeod Street Disc.
Old Oct 7, 2004 | 03:46 PM
Swirk's Avatar
Swirk
Thanks everyone.
I need to find a clutch disc with a center sprung section that measures less than 6" in diameter.
CYLT4, After you get that clutch out, measure the center section, ,if it is less than 6", I will make you an offer.
Old Oct 8, 2004 | 09:58 AM
LD85's Avatar
LD85
I got this:
Part# 37-261871
McLeod Performance Clutch Disk, Shifts to 7500 RPM, 1993-1997 LT1 F-Body
$133.33
www.thunderracing.com
Old Nov 25, 2004 | 06:47 PM
96CERon's Avatar
96CERon
Just put the same Fidanza plus stage 2 in my LT4--Same problems--no big deal on noise at idle but loud gear clatter from 900 to 2000 and heavy vibration from 3000 up--also didn't match balance to original DM because supplier said I didn't need to--wrong! Ohter than that engages and runs ok.
To Single Mass Flywheel Conversion gurus
