Code 43????
Old Oct 7, 2004 | 05:30 PM
ABNVET.I's Avatar
ABNVET.I
Default Code 43????
Im getting a code 43 when I checked it. Not sure what the definition of this means. Can someone give me a hand on what it may be?
Old Oct 7, 2004 | 05:39 PM
mikey whipreck's Avatar
mikey whipreck
Code 43... knock sensor... could be a number of things, wiring to/from the knock sensor, faulty knock sensor, fault ESC module.... do a search for this. You do have a Haynes or Helms manual right?
Old Oct 8, 2004 | 03:08 AM
jzvette's Avatar
jzvette
I hear the quick cure for code 43 is new knock sensor.
Old Oct 8, 2004 | 03:14 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2043.pdf
Old Oct 14, 2004 | 01:04 PM
ABNVET.I's Avatar
ABNVET.I
Thanks all!
Old Oct 14, 2004 | 03:19 PM
mikey whipreck
Originally Posted by 1hot90
Thanks all!
did you fix it? what was the solution?
Old Oct 14, 2004 | 03:35 PM
aklim's Avatar
aklim
Another thing could be a loose KS wire or the connector. Ask me how
I know
Old Oct 14, 2004 | 09:22 PM
CeeFour's Avatar
CeeFour
I just repaired this on my '92 Vert. I cleaned the connectors on both knock sensors and bent the center connector a little so it would make better contact. No more 43's.
wawctw's Avatar
wawctw
I had a code 43 on my car for some time. I found it to be two broken wires in the harness running from the esc. THE ESC IS LOCATED NEAR THE HEATER MOTOR UNDER THE HOOD. Another thing to check is the brown whire in this harness which is a ground. Make sure that there is a good ground to this wire. I ran a new one to the hood hinge above this wire. Hope this helps!
To Code 43????
