Flat Tire Adventure!!
Old Oct 8, 2004 | 01:01 PM
NJ96VERT's Avatar
NJ96VERT
Default Flat Tire Adventure!!
OK, Where are you supposed to store the flat rear tire?
I had to drop the convertible top, move up the seats, tilt the seatbacks forward, so that I could wedge the rim behind the seats!!
At least it wasn't raining! Looked like a monkey driving with the seat in that position....What am I missing? The 285/40x17 certainly doesn't fit where the spare goes? Or does it?
Old Oct 8, 2004 | 01:05 PM
LT1FORFUN's Avatar
LT1FORFUN
Spare tire carrier has two positions on hinge...one for space saver and one for big tire and wheel....Look in your owners manual if you have one
HE
Old Oct 8, 2004 | 01:11 PM
NJ96VERT's Avatar
NJ96VERT
ok, thanks, I have a knack for making myself feel really stupid....
Old Oct 8, 2004 | 02:02 PM
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
I'm still cracking up about the Monkey visual
Old Oct 8, 2004 | 02:11 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Me too...that was a great line.
Yep, the carrier does drop to hold a regular tire. Which makes me think that anyone who still carries the spare might want to replace it with a real tire mounted on a real wheel and just rotate the spare along with the other 4.
Old Oct 8, 2004 | 04:09 PM
NORMSTOY 89's Avatar
NORMSTOY 89
Most of us are running directional tires and wheels which makes rotation a problem.
Old Oct 8, 2004 | 05:45 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Not only that, but radials in general should only be rotated front to rear on the same side. Once they have been run in one direction, that should not be changed.
Old Oct 8, 2004 | 11:38 PM
rws.1's Avatar
rws.1
Hmmmm, The manager at the local Discount tire told me that front to back only tire rotation on radials is an old wives tale...
Anyone have thoughts on that?
Old Oct 9, 2004 | 12:48 AM
jfb's Avatar
jfb
Front to back for radials IS an old wives tales, BUT.....directional tires should not change sides!
Old Oct 9, 2004 | 01:57 AM
SLOWRIDE's Avatar
SLOWRIDE
Old Oct 9, 2004 | 02:17 AM
EPiC Vette's Avatar
EPiC Vette
WOW! Your spare had air in it?
Before I took my first "road trip" I dropped the spare (and found the jack!) and discovered it only had about 10# in it.
And swamp goo in the tray.
To Flat Tire Adventure!!
