Winking headlights! (1990)
Old Oct 8, 2004 | 03:45 PM
Narnian's Avatar
Narnian
Default Winking headlights! (1990)
I remember seeing this covered on this board before, but for the life of me I can't find the right posting.
My headlights are taking turns opening up. Sometimes they will both open halfway and bob around lighting up the inside of my engine compartment. Sometimes the left one will open up correctly but the right one will only go halfway, and sometimes the right one will open all the way but the left will only open halfway. On rare occasions they will both correct themselves as I'm driving.
Does anyone remember how to diagnose and fix this?
Old Oct 8, 2004 | 04:06 PM
eptaylor's Avatar
eptaylor
You need to replace the nylon bushings in the headlight motor assembly. Lots of people will chime in on how, if not i will
Old Oct 9, 2004 | 02:47 PM
Narnian's Avatar
Narnian
Bummer!
So basically the nylon bushings in both headlights decided to take a nose dive at the same time huh?
I'll give Mid-America a call on Monday. Any pointers on changing those bushings will be welcomed.
Old Oct 9, 2004 | 03:01 PM
NightFlight's Avatar
NightFlight
There's a Tech Tip article on how to do it for your model years ... If you do a search, you should be able to find it, very well written from what I remember.
Old Oct 11, 2004 | 01:15 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Once you get the replacement bushings, use these instructions to install:
http://www.corvetteforums.net/tech/headlight.html
To Winking headlights! (1990)
