92 Lt1 Running rough...
Old Oct 10, 2004 | 06:01 PM
WYTEOUT92's Avatar
WYTEOUT92
Default 92 Lt1 Running rough...
I have a 92 LT1 Auto Coupe (White w/beige, FX-3, Sport Seats) that I bought in May. It was part of an Estate settlement and had been in storage for over 1 year. I paid $6000 for this 90,000 mile 2 owner car. It has turned out to have been an excellent bargain and thus far (3000 miles this summer) I have really had no problems with it.
Improvements have included the obligatory spring LOF (Molil One), coolant flush, FI power flush,and a major tuneup- including plugs, wires, optispark (ouch), pcv valve, fuel filter. Modifications have involved, K&N cut box filter, 160 degree thermostat, tbi performance chip, moved MAT sensor, and ss Magnaflows.
The car has run absolutely fantastic all summer, smooth, fast, and cool.
Today, I take her out for what will probably be the last top off drive of the year and she is running rough. Idles slightly rough, but really noticeable under acceleration. When I put my foot into it, the response is really sluggish and it feels like there is a lot of detonation going on. Seems like 4-6 cylinders are firing. Under WOT it totally bogs down.
What is going on here- I put 100+ miles on her yesterday and she ran absolutely perfect.
Old Oct 10, 2004 | 06:40 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Please tell me they flushed the cooling system before they changed the opti.
If so, check the codes, it could be the fuel filter or a clogged injector. Try disconnecting one cylinder at a time to pin point it.
Sometimes just sitting in a garage can do a lot of damage, most museum cars won't turn over!
Old Oct 10, 2004 | 06:49 PM
FD2BLK's Avatar
FD2BLK
Pull codes and see what you get. A bad O2 sensor will cause similar problems to what you are describing but so will a bad opti.
Old Oct 10, 2004 | 07:36 PM
WYTEOUT92's Avatar
WYTEOUT92
Oh, yeah- cooling system definitely flushed prior to OptiSpark replacement.
I understand about all the bad stuff that can happen when a car sits an extended period of time, but keep in mind that this thing has been running excellent all summer.
This condition just started today
Old Oct 10, 2004 | 07:43 PM
runner140*'s Avatar
runner140*
Default Running rough....
Sounds like you should be throwing a code... check codes first. Sound like your opti. To check, pull your plug wires and check for a spark. That should be a good place to start.
Old Oct 10, 2004 | 09:38 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
Possible condensation in gas tank? Try running some Redline fuel injection cleaner through there. Hey, $5 won't break they bank
Old Oct 11, 2004 | 02:56 AM
bogus's Avatar
bogus
you will want to check the following areas:
1) Coil wire - this can chaif and ground out, causing this problem.
2) Coil - yup... they do just up and quit.
3) Ignition module - the coil is attached to it. They also just quit.
4) Fuel pump - If it ain't pump'n, you ain't drive'n. Check the pressure with a fuel pressure gauge, should be at 43psi at idle.
Don't blame the opti just yet, check these other things. They will fail without throwing a code!!!
Old Oct 11, 2004 | 09:39 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Also make sure you aint runnin the original O2 sensors!
Old Oct 11, 2004 | 01:04 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Don't forget to clean your throttle body, too. It's a good idea to inspect annually and clean accordingly. Really helps 'em idle smoother and perform better.
Old Oct 12, 2004 | 04:21 PM
WYTEOUT92's Avatar
WYTEOUT92
Took it into the shop today. Turns out it's 2 bad injectors. Having them replace all 8 while it's in. Looking forward to getting her back.
Old Oct 13, 2004 | 10:20 AM
Teenangel's Avatar
Teenangel
Default Bad Gas
I had the same problem. Check engine light on? Could be Bad Gas.
I would run my tank down to Empty and fill up with Sunoco 94 Ultra and add a can of Octane Boost. That my do it
Old Oct 13, 2004 | 02:28 PM
WYTEOUT92's Avatar
WYTEOUT92
No check engine light
To 92 Lt1 Running rough...
