Idle problem when stopped
Old Oct 11, 2004 | 06:56 PM
eddieL98's Avatar
eddieL98
Default Idle problem when stopped
when the vette is cold it seem to idle fine.
when it warms up or maybe just after it's been running a while it starts acting funny.
when i stop the idle is fine for about 20 seconds the it seems to drop a few hundred rpms almost to a stall.
i have a code reader and no codes came up.
does anyone have an idea?
'90 L98 coupe
Old Oct 11, 2004 | 07:03 PM
CFI-EFI's Avatar
CFI-EFI
How long has it been since the IAC passages have been cleaned?
RACE ON!!!
Old Oct 11, 2004 | 07:21 PM
mikey whipreck's Avatar
mikey whipreck
Hmm... You should take a look at this thread...
http://forums.corvetteforum.com/showthread.php?t=922612
Old Oct 11, 2004 | 07:22 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Clean the TB and the IAC; reset base idle.
Old Oct 11, 2004 | 08:09 PM
bmalec's Avatar
bmalec
I had the same problem here, in my case it was the injectors. But these guys are right, clean out the TB and IAC first to see if that solves the problem
Ben
Old Oct 11, 2004 | 09:09 PM
onetrackmind's Avatar
onetrackmind
Disconnect the 02 sensor and see if you still have the same problem.??
Old Oct 12, 2004 | 10:26 AM
eddieL98's Avatar
eddieL98
thanks guys i'll check it out. it shouldn't be the O2 sensor I replaced it a few months ago. IAC on the other hand has been with the car for 7yrs now...oops
sorry Mickey but i'm in the middle of moving no DSL and dial-up is way to slow to do a search. thanks !!!
Old Oct 12, 2004 | 10:36 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check your PCV valve, too. I replaced mine about three weeks ago and it was either O.E.M. or seriously way past it's service life. It was embarrassingly discolored and partially clogged up.
My base idle's much better now. It's just one of those things that's easy to overlook...and even easier to replace.
Old Oct 12, 2004 | 03:46 PM
eddieL98's Avatar
eddieL98
how do you reset base idle? i can't see where you tighten the screw by the throttle. I replaced the IAC and am still getting the problem. will try the pvc next and a can of cleaner
Old Oct 12, 2004 | 04:10 PM
mikey whipreck
As I understand it, you don't mess with the screw, you need to adjust the TPS voltage (the tech tips section will tell you how to do that). As for the IAC, I'm assuming you reset that after you put it in?
Old Oct 12, 2004 | 04:23 PM
eddieL98's Avatar
eddieL98
reset the IAC? not sure what you mean
but i just replaced the PVC and cleaned the throttle body still when at idle it surges low. dies when in drive.
Old Oct 12, 2004 | 04:48 PM
eddieL98's Avatar
eddieL98
ok just rest the IAC. found it in the service manual. still having problem.
car starts fine idles at about 900rpm
warms up and drops to about 700
i place it in drive it drops to 650 or so
when I give it gas no problem no hesitation
when I let it idle it surges low
I trun the a/c @ idles car dies too much load.
oil pressure low ar idle but i guess that's due to low idle
runs normal at speed.
Old Oct 12, 2004 | 05:05 PM
bmalec's Avatar
bmalec
Check injector resistance?
Ben
Old Oct 12, 2004 | 05:06 PM
mikey whipreck
That makes me think you fixed one problem and found another... I believe surging low is showing something wrong with your distributer, coil maybe? Perhaps someone else has a better guess.
and you're right- low idle will cause low oil pressure...
Old Oct 12, 2004 | 09:37 PM
C4Me's Avatar
C4Me
I have idle problems with my 89'. Runs fine when cold them once it warms up I get surges and rough running at idle. Used an Ohm meter on the injectors and found 3 that were reading bad. 5 of the injectors were reading 17.4 ohms but 1 reading 3.4, another reading 10.2 and the 3rd reading 14.1....gonna replace injectors now.
Worth a shot.
Old Oct 14, 2004 | 11:35 AM
eddieL98's Avatar
eddieL98
took car to the shop to test. they said it could be the EGR since it's not holding pressure or the injectors. the car is running rich making it stall at idle.
I have accell injector not sure what the specs as in ohm goes but they are at 15ohm. will have to go to the site or call them to check.
going to pull the egr since I already have one.
actually I have a new intake setup in storage I never got around to installing. since i have to pull them might as well replace it.
high flow intake & runners/ plenum.
if the injectors turn out to be bad any recomendations??
Old Oct 14, 2004 | 12:04 PM
mean8t's Avatar
mean8t
I just checked the site 14.4ohms
Old Oct 14, 2004 | 12:16 PM
SunCr's Avatar
SunCr
The injectors look ok - unless one is leaking - at least the resistance is normal. The fact that it stalls when you turn on the a/c may be an ECM problem. You need to hook up a scanner and monitor the a/c request signal and IAC counts. The scan should show a "Yes" when the compressor clicks on and the IAC counts should increase. If not, the ECM or the wiring is funky, particularly if you've cleaned or replaced the IAC. You should also check fuel pressure and vacuum. I'm surprised that the mechanic didn't do this to narrow down what's going on. Did he explain what he meant by the EGR not holding pressure? Manifold pressure or vacuum should keep it closed at idle but without taking it off to inspect the pintle and the manifold seat, it's difficult to tell.
Old Oct 14, 2004 | 12:20 PM
mean8t's Avatar
mean8t
How does the computer know if the A/C is on? Does the wiring harness connect to the compressor or something? Can you buy that piece? My compressor is from an 80 Vette so it doesn't have anything to connect to the computer.
thanks
To Idle problem when stopped
