Bose speaker amp schematic
Old Jul 31, 2001 | 10:50 PM
90Conv's Avatar
90Conv
Hello,
I am starting to collect dead bose speaker amps. Mine seem to be dying at a regular pace. I have replaced with new, but would like to fix the dead ones to keep as spares. I have tried the common capacitor replacement
fix with no success. I am looking for a detailed schematic for the front and the rear
Bose gold local amps. Does anyone know where I can get them? Thanks for you help
Charlie M
Old Aug 1, 2001 | 07:39 AM
89 Bob L's Avatar
89 Bob L
Check the c-4 tech tips for the bose amp. Stewart Sloke is the editor. It 's a start
Old Aug 1, 2001 | 08:17 AM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
Those amp's are a real pain. How could Chevrolet put together a fantastic car with an audio system that's as bad as that Bose system ?? Between the amp's and the rotten radio reception the radio is a garbage candidate. It would be great if someone could rebuild those amp's so they don't go down as easy. And find a way to get a lot better radio reception.
Old Aug 1, 2001 | 09:12 AM
DON M's Avatar
DON M
Gordon Killebrews book talks about a "ground plane kit" that GM has to improve reception. It is a wire that acts something like a reflector that goes into the car. Normal rust buckets don't have the problem because of all of the metal. It would be worth a try.
Don
Old Aug 1, 2001 | 09:42 AM
FU's Avatar
FU
Don
Don, can you tell me the title etc. on Gordon's book so that one can be purchased ? There is a ground kit offered by Chevrolet for poor radio reception. TIA
Old Aug 1, 2001 | 09:58 AM
vette_tweak's Avatar
vette_tweak
You don't always require a schematic to troubleshoot an amplifier. I've never had a close look at my bose amp but amps are very similar. Is the fuse feeding the amp(s) blown? If so it's probably the output devices ( mosfets or bipolar transistors ). You can check them with an ohm-meter. Feel free to email me for more detailed info.
If there's enough interest, I'll yank my bose amps and maybe get into fixing them. What would it be worth to you for an amp repair?
( my daytime job is an electronics designer for a major home audio company, I mostly design amps )
Old Aug 1, 2001 | 10:20 AM
vette_tweak
Here's a guy who will repair the amp for $30!
http://www.corvettedashclusterservic...20starter.html
Old Aug 1, 2001 | 03:54 PM
jg84's Avatar
jg84
I've got an 84, and it appears that when I use a tape all speakers work great. When I use the radio it appears that the drivers side speakers are not as loud as the passenger side. Is this the amp problem?
Old Aug 8, 2001 | 10:46 AM
FU's Avatar
FU
Default Re: (vette_tweak)
Thank's for the link vette_tweak.
jg84 does the speaker in question pop when you turn the stereo on ? If so the amp is on it's way out.
To Bose speaker amp schematic
