Spark advance
Old Aug 1, 2001 | 01:20 AM
GRX's Avatar
GRX
Can anybody help me determine the correct spark advance while idling or in cruise? My diacom shows 0 degrees while idling. It shows 0 degrees when I start out. I don't have any error codes set.
Old Aug 1, 2001 | 02:49 AM
88L98's Avatar
88L98
Cruise-In II Veteran
if i remember correctly, my scan software says im getting about 13-14 degrees advance at idle. are you talking about advance? you should be seeing more than 0 degrees. how it running?
Old Aug 1, 2001 | 09:29 AM
GRX's Avatar
GRX
It was running kind of rough; but not very noticeably rough. Enough for me to notice.
No error code though.
Old Aug 1, 2001 | 12:01 PM
DOCTOR J's Avatar
DOCTOR J
I'm guesing you have around a '90 vette. If so, there are several tables in the ECM that control spark. One of them will show 0* advance relative to ref at 0 TPS in closed loop (if I recall it right) - at that point spark is being controlled by another table, which would be applying about 20* total advance for idle. Diacom should be showing two spark readings - one w/r/t ref, the other total BTDC. They should not both be 0*. That's my guess, anyway. YMMV.
DrJ
Old Aug 1, 2001 | 01:59 PM
GRX's Avatar
GRX
It's an 85.
Old Aug 1, 2001 | 02:06 PM
Goody's Avatar
Goody
Leaving diacom out of it for a bit, have you run a timing light on it?
Old Aug 1, 2001 | 03:37 PM
GRX's Avatar
GRX
Not recently. A few weeks ago I went through the timing setup procedure before the smog test-car passed perfectly. I guess I should recheck it before anything else.
Old Aug 1, 2001 | 11:07 PM
smallblock's Avatar
smallblock
I'm not sure how well diacom works with an 85 computer.
To Spark advance
