Nice Lt4 383 on ebay
Old Oct 13, 2004 | 12:36 PM
LT1Vetteguy78's Avatar
LT1Vetteguy78
Default Nice Lt4 383 on ebay
Check this bad boy out
LT4 383
Old Oct 13, 2004 | 12:53 PM
Timmy!'s Avatar
Timmy!
I think he might be exaggerating a little on the HP #'s though, unless his 650HP # is with the NOS.
Old Oct 13, 2004 | 12:55 PM
Timmy!'s Avatar
Timmy!
I think he is exaggerating the HP#'s a little though, unless his 650HP # was with NOS.
Old Oct 13, 2004 | 12:57 PM
Cherry6speed's Avatar
Cherry6speed
Dayuuuum Is that thing streetable???
Old Oct 13, 2004 | 02:00 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
It seems like a lot of HP for the flow, compression, and cam he indicates.
I have no doubt it is 500+ though.
Old Oct 13, 2004 | 06:32 PM
zelement's Avatar
zelement
no way this thing is 650hp. This is just a street/strip 383 LT4 nothing special about it. This is more like a 420rwhp and 11 sec motor.
You are not going to get 650hp with 300cfm heads, 12:1 CR, and near .600lift cam.
Old Oct 13, 2004 | 06:43 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
I was going to say damn maybe my build up in progress will end up 500+ hp
Old Oct 13, 2004 | 06:46 PM
bogus's Avatar
bogus
how does a .030 over bore cost $4700.00????????
Old Oct 13, 2004 | 07:37 PM
93Quasar's Avatar
93Quasar
That was my first thought too. Even the bill for clearancing and align boring (assuming it was done) shouldn't come near close to that, including the block price. I don't even think bowtie blocks cost that much.
Old Oct 13, 2004 | 07:54 PM
xs650's Avatar
xs650
It will, just rate in in EHP, eBay HP
Old Oct 13, 2004 | 09:38 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Too true
Old Oct 14, 2004 | 08:27 AM
LT-4 CE's Avatar
LT-4 CE
Yep, that's what I was saying too. 300cfm is way too much cylinder head for the average street strip motor and way too much for that cam shaft.
Old Oct 14, 2004 | 08:57 AM
LT4BUD's Avatar
LT4BUD
I really don't understand this, but this site seems to support the possibility of 650hp from 300cfm.
http://www.malcams.com/legacy/misc/headflow.htm
HP=300*.257*8=616.8
or
CFM=650/.257/8=316
Old Oct 14, 2004 | 09:50 AM
LT-4 CE's Avatar
LT-4 CE
I am not arguing that it is impossible, but I've seen quite a few N/A small blocks with some pretty good heads and 650 horse power is a hefty number.
I can't recall what Ski and Jeb are making, but they are running hand-built intakes and bigger rollers (I think), and more cubes to run in the low/mid-10s. This guy claims 9's in a 3400 lb Camaro - it takes more than 650 to go 9s in that heavy of a car.
I just don't know that the cam is enough to support that kind of HP with the rest of the combo - it just doesn't look to be a perfect match. But none of us have seen the dyno sheet or the head flow charts to really know what lift they are flowing best or where the engine is making it's power.
Of course, I have been wrong before and will be wrong again.
Old Oct 14, 2004 | 11:08 AM
Timmy!'s Avatar
Timmy!
I think he's double charging for stuff. I would say that the $4,700 for the boring of the block included the crank, rods, pistons and a few other things and then he separated them out to make it look like it cost a lot more than it did to try and get his money out of it.
Old Oct 14, 2004 | 04:58 PM
loiq's Avatar
loiq
Bowtie aluminum blocks don't even cost that much.
Old Oct 14, 2004 | 06:31 PM
1996man's Avatar
1996man
so 300cfm is to much flow for that cam? so if he had a bigger cam(although it would make it less streetable) it would make more power? i agree that 9s with a 3400lb car is impossible unless you put juice on that thing.(with this paticular LT4)
i would definatly like to see the head flow charts, as well as the dyno sheet to see the power band. that would show us more of what the cam is doing. he says the motor is built for NOS yet i dont see anything about the internals being forged.
im kind of surprised he is still running a regular waterpump and not an electris one to free up more power. and doesnt 36lb injectors seems a little small for that kind of power at that high of compression?
you can still run 93 octane in that motor for "street use" right? since its a reverse cooling design cant they run at higher compressions with lower octane than most motors? i would think you would want race fuel in it if you were going to wind the tach up though.
i dont know why he spent all that money and didnt get ceramic coated headers....
im also curious why he didnt just go with a 396 bore and stroke.
seems it would be a little easier to get teh power he was looking for and that way you can get a really high revving cam to get that peak HP he wanted without suffering as much low end loss cause you have more displacement to give you more tq!
To Nice Lt4 383 on ebay
Old Oct 14, 2004 | 07:09 PM
zelement's Avatar
zelement
HP=300*.257*8=616.8
or
CFM=650/.257/8=316
I am assuming his head flow 300cfm @.600lift. His cam on the intake side doesn't even reach .600 therefore he won't see 300cfm.
I don't think his heads are too big for the cam but he could have choose a cam with a little more lift to utilize the good flow of his heads.
I am not good with math and I don't know how they come up with those numbers but I would think CR would be a factor in Hp as well. I am sure you can make the numbers match on paper but doing it in real world is a completely different story. Take Desktop dyno for example, it is nothing but numbers inputed into the computer but the results always fall short...by a lot.
I also think 316cfm is a huge difference when compared to 300cfm. If I had heads that flow 16 more cfm I would probably gain 50rwhp.
Old Oct 15, 2004 | 12:27 AM
Bruce's Avatar
Bruce
650hp noway. I would bet about 550fhp. I am compare to Phil old 401LT1 with big solid roller cam and AFR 220 heads with addtional portinng 12:6:1 C/R and made exactly 500rwhp on pump gas.
Bruce
Old Oct 15, 2004 | 02:48 AM
1996man's Avatar
1996man
phil tobin? as in the owner of "HOOVER"? hes only making 500rwhp? and hes running a 10.64? WOW DAMN! can that man launch or what?
