Computer Question...
Old Aug 2, 2001 | 02:23 AM
KDuniverse's Avatar
KDuniverse
Ok, I'm no genius when it comes to car electronics but I have a question. Ok, I have a '93. I know these can't be reprogramed or "upgraded". So, why can't you just switch out this ecm for a newer one, say a 96? This way they can be reprogramd with a power programer or something. This maybe a stupid question, but I don't know the answer.
Old Aug 2, 2001 | 09:45 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I suspect the newer ECM has different connectors along with new I/O. The interconnections are a BIG deal.
Old Aug 2, 2001 | 09:46 AM
-=Jeff=-'s Avatar
-=Jeff=-
if you got an engine harness and PCM from a 96 it might work in your car
Old Aug 2, 2001 | 01:49 PM
KDuniverse's Avatar
KDuniverse
Has anyone ever done this?
Old Aug 2, 2001 | 02:49 PM
ZylaRace's Avatar
ZylaRace
Every year is slightly different. The harness changes w/ options and upgrades. Yes, it can be done, but you are talking about a fair amount of work and expense.
Old Aug 2, 2001 | 09:32 PM
Warlock's Avatar
Warlock
Default Re: (KDuniverse)
Who says you cant? And why not? I think you've been told wrong.
Old Aug 2, 2001 | 09:33 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
Default Computer Upgrade
One of the biggest changes with the ECM was in the 96 Model year. GM went to the Onboard Diagnosis II. This system uses over one hundred different inputs for the ECM. Such little things as the fan not turning on when it is suppose to will triger the check engine light. The older ECM's did not have this much monitoring capability. It would probably turn into quite the project. Good Luck!
Old Aug 3, 2001 | 12:09 AM
Aaron's 87's Avatar
Aaron's 87
You can reprogram your 93 easier than a 96. Look at tunercat and LT1 Edit. Have you made any mods to warrant a change? PS - Are you a trainer?
Old Aug 3, 2001 | 01:12 AM
Chris@SD's Avatar
Chris@SD
Tunercat has software to burn a new chip for your car. Any of the chip tuners can make you a chip if you do not feel comfortable doing this yourself. The upgrade is not that hard, but also not worth it.
LT1 edit will not work on your car. This will only work on '94 and later LT1 motor cars.
Good Luck,
Old Aug 3, 2001 | 01:06 PM
KDuniverse's Avatar
KDuniverse
Default Re: (2FST4U)
Does anyone have some websites that I can get some info from? I want to learn/know as much about these computers as possible. Aaron's87, yes I am!
Old Aug 3, 2001 | 01:10 PM
Aaron's 87's Avatar
Aaron's 87
Check http://www.tunercat.com and http://www.lt1edit.com (not sure on that one - do a search if it doesn't work). Without motor work, the most you'd want to change on a stocker is fan turn on temps, shift points and firmness, and gear ratio if you changed it. With motor mods, then you have to start playing with fuel and timing. Check your email.
To Computer Question...
