Proper vent operation
Old Oct 13, 2004 | 07:30 PM
Duf's Avatar
Duf
Default Proper vent operation
My 88 with climate control has had very weak airflow since I bought it. This evening, following the excellent instructions here, I replaced blower motor with little trouble. Doing so helped my air flow. Not quite as much as I hoped but it is definitely better and when I go through the different fan speeds it actually changes the amount of airflow when before it didn't. My question is when you have it set to the AUTO ac setting, should all of the air be blowing out the dash vents? In my car there is a significant amount of air coming out of the defroster vent at the same time. If I change the setting to defroster, the dash vents stop and it all goes to the defroster but if I go back to AUTO, there continues to be a lot of air coming out the defroster. If this is normal behavior, oh well my bad, if not, I'd like to see if I can fix it because if the air coming out the defroster was pushed out the vents, I think I would have much better cooling in the vehicle.
Old Oct 13, 2004 | 09:45 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I don't recall any ac comming out of my defroster vent in auto. Sounds like a problem and I'm no expert. I can email the diagnostics from my 86 manual if you like.
Old Oct 13, 2004 | 10:08 PM
fundriving's Avatar
fundriving
Duf, The A/C-Defrost door is a 3 position door. In Defrost setting, all air is diverted to the defrost vent. In the Bi-level and Heat setting, the air is primarily diverted to the A/C vents at the floor and dash. In the A/C or Vent setting all air is diverted to the A/C floor and dash vents, No air to the defrost... so, it sounds like you have a door that is not moving fully thru is range.
Old Oct 13, 2004 | 10:17 PM
Great White North's Avatar
Great White North
Old Oct 14, 2004 | 09:09 AM
Duf's Avatar
Duf
Hmm ok , anybody have any direction on how to remedy something like that? I have no idea.
Old Oct 14, 2004 | 08:31 PM
JD JOHNSON's Avatar
JD JOHNSON
Default Check My Threads
HAD THE SAME PROBLEM ON MY 94. THE DIVERTOR VALVE BROKE OFF AT THE TIP. CHECK (Shoregasm thread titled what is this? Changed mine now air blowing like a champ from the dash...........................
Old Oct 14, 2004 | 08:46 PM
Shore's Avatar
Shore
Damn!...beat me to it........lol
Old Oct 14, 2004 | 09:00 PM
Great White North
The Front and Rear Mode Valves determine wether air flows to the Heater Outlets or the A/C-Defrost Outlets or both. In the HTR Mode both valves are in position B which directs all air flow to the Heater Outlets. In the ECON Mode both valves are in position A directing all air to the A/C-Defrost Outlets. IN BI-LEV the Front Mode Valve is in position A and the Rear Mode Valve is in position B. Air flow is then directed to both the Heater Outlets and the A/C-Defrost OUtlets. When operating in the AUTO Mode the Heater and A/C Control Assembly determines the positions of the mode valves from the exisiting cooling or heating requirements. Direct from the manual.
To Proper vent operation
