tech questions on my 96 vette?
Old Oct 14, 2004 | 10:49 PM
mpvette96's Avatar
mpvette96
Cruising
Default tech questions on my 96 vette?
I have a 96 corvette and am experiencing wierd things from my transmission. when i drive between 49-59 it goes into a lock up point and if i stay around a certain speed between 49-59 my transmission will sometimes shift up and down continously unless you stop going that certain speed and accelerate more. Now I have been told by many people that that is normal for the lock up point in the transmission but I want an opinion on this from a corvette owner. Also, I first started hearing the noise after I put my magnaflow exhaust and new wheels and tires on, I am not sure if that would have anything to do with it or not, What do you guys think?
Old Oct 14, 2004 | 11:44 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
If you're staying at a constant speed between 45-60mph without moving the throttle and its going in and out of lockup alot I'd have it looked at. Some is normal if you move the gas pedal but not alot. If it were mine I'd hook a scan tool up to it and watch it while driving (or have someone else watch it while I drove) and see what signals its getting. I know thats not much help but its about the best I can do without some sort of scan tool like a tech 2.
Old Oct 15, 2004 | 08:39 AM
runner140*'s Avatar
runner140*
Default Have it looked at....
I also have a 1996 and drive at that speed constantly and have never experienced shifting. It is not normal and might be signaling a problem.
Old Oct 15, 2004 | 12:51 PM
RIISITAS's Avatar
RIISITAS
My 96 does not lock and unlock like that.
Old Oct 16, 2004 | 05:05 PM
mpvette96's Avatar
mpvette96
Cruising
Thanks for your reply on the trans. Q' , Have you put new wheels and tires on your vette? I have put 18 all the way round and think that that might throw the lock up point off in the comuter , do you think thats the possible problem?
Old Oct 16, 2004 | 06:52 PM
redbullapril23's Avatar
redbullapril23
mine dont lock up!!!!
1996 a4
Old Oct 16, 2004 | 07:41 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Especially since the advent of electronic trans control, this kind of "hunting" should not be a problem. Ask around a LOT, to find one and then talk to a real transmission expert.
To tech questions on my 96 vette?
