Fuel Presure Regulator Mod?
Old Oct 15, 2004 | 12:06 PM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Default Fuel Presure Regulator Mod?
Does the fuel presure regulator modification as described in C4 tech tips section really work? Has anyone else tried it?
Old Oct 15, 2004 | 01:59 PM
Shore's Avatar
Shore
I noticed his was an 88 C4...how about for a 92 Lt1..
Old Oct 15, 2004 | 08:01 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Don't do it
Buy and adjustable one if you want to mess with the fuel pressure. With that so called tech tip your fuel pressure will be max all the time. Not a good thing
Old Oct 16, 2004 | 06:02 PM
89Corvette6spdFX3
Originally Posted by AGENT 86
Don't do it
Thanks, I think I'll take your "tech tip" advice.
Old Oct 16, 2004 | 07:03 PM
Steel Blue 91's Avatar
Steel Blue 91
Don't do it
With the vacuum removed, it will call for full fuel all the time. Get an adjustable FPR if you want to make changes in your tune.
Old Oct 16, 2004 | 11:36 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
does anyone check these "tech tips" for accuracy when they're submitted? Just read this one and I quote: "if you can stand the noise you can also spring for performance mufflers and obtain a 30-50 HP increase plus a torque increase you can feel." dang I need some of those mufflers! I'll be happy if I get anywhere near that increase from my long tube headers!
To Fuel Presure Regulator Mod?
